use of periodic bc
Old   January 19, 2004, 20:26
Default use of periodic bc
subhra
When one applies periodic bc to velocity and pressure, it is said : "End section of domain wraps up with start section of domain.."..is it ok to think that the domain is in the shape of a loop? Even if I don't use any co-ordinate transformation to unwrap the physical shape of the loop (say a donut) into the geometry of simulation (in my case, plane channel) ?
..any advice/comments on this will be greatly appreciated...
actually I simulated a plane 2-d channel (containing an electrohuydrodynamic flow generating element) using periodic bcs to velocity and pressure at inflow and outflow...but I am not clear to what extent does it make sense to interpret this as a flow loop pumped by the element...
the other interpretation I can think of is element is one of a streamwise series of repeating elements in a developed flow..but that's not what I want and further that will probably require a pressure drop?
Thread Tools
Trackbacks are On
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 0 September 20, 2011 07:58
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Periodic boundary condition Arif FLUENT 0 May 1, 2003 04:02
