URANS for unsteady flow?
Old   December 3, 2009, 11:06
Default URANS for unsteady flow?
karine
thecfduser is on a distinguished road
Hi all
i have some little questions:
1-can URNANS models predict unsteadiness in flows? like vortex schedding???
2-The average solution for URANS flows is it the same than the solution of steady RANS ???
thanks and regards
thecfduser is offline   Reply With Quote
Old   December 9, 2009, 18:28
sfalsharif is on a distinguished road
Originally Posted by thecfduser View Post
Hi all
thanks and regards
The quick answer is:
1. Yes they can, but not with complete confidence. You need to do some validation against experimental or perhaps higher accuracy, trusted simulations to make sure your results are acceptable.
2. Not necessarily. It depends on the problem. There might be non-linear interactions between 'organised' unsteadiness and the random fluctuations that alter the time-mean solution. In such cases, you need to be wary of URANS results.
sfalsharif is offline   Reply With Quote
Old   December 10, 2009, 13:42
karine
Thank u very much, but i didt understand too much the second point
In fact, what u are saying is true: URANS will not give a trusted result, but this will be the same for steady RANS.
My question is if we do the same simulation with steady RANS, than with Unsteady Rans and we take the average of the URANS solution, will the 2 solutions be the same????
I know that the mean solution of non-linear equations is not necessarely a solution of the equation , but i am not 100% sure....
Thank u
Old   December 11, 2009, 21:12
Thank u
Not in general. In fact, if the problem is intrinsically unsteady and you try to solve it with a steady RANS solver, you'll most likely have difficulty getting converged results.
But even if you do get a converged solution using a steady RANS solver, it may not be the same as the time-mean of the solution obtained with an URANS solver. If you have a quasi-steady rate of variation, where the large-scale variations of flow conditions over time are slow enough such that at each instant in time the turbulence is able to re-adjust to the new conditions as if it were at a new equilibrium state, then you might expect the to get agreement between the time-mean and the steady solution. But if not, i.e. if the rate of variation is too fast for the turbulence to adjust to new conditions, then you probably will not have such an agreement.
There can be other complicating factors, such as periodic laminarisation and re-transition in pulsatile pipe flow (happens under certain conditions), for example, which might throw-off the turbulence models in a cyclical way (models are less than perfect in predicting transition). In which case, the time-mean solution you get will be different from the corresponding steady solution without forced pulsations. This is to name one example.
Old   December 12, 2009, 16:12
karine
OK thank u very much for ure answer
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
