February 2, 2010, 11:09 |
time step!!!
Vijesh Joshi
Rep Power: 17 |
Hello friends,
I am solving 1-d transient heat conduction equation by FVM. I am trying to analyze "heat flow through a very thin sheet of steel". Sheet thickness is 0.5mm. q on one side is given AND IS VERYING WITH TIME. Becoz of higher K (43 W/m-K) value of steel, I am in need to use very small time step. I used dy=0.5mm/3=0.167mm=1.67e-4 m.. dt=0.01sec ... But results are not converged.. I am using fully implicit scheme to solve the transient cond eq... Do I need to worry abt Courant number?? Is there any other way that I can solve this problem with higher time step??? |
DPM particle time step | amos | FLUENT | 1 | January 4, 2020 08:46 |
HELP! time step too small? | meangreen | Main CFD Forum | 6 | May 31, 2018 10:41 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Overflow problem in steady simulation | ReeKo | CFX | 11 | October 8, 2008 17:57 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 22:00 |
