setting boundary condition for curvlinear grid
Old   February 5, 2010, 04:40
Default setting boundary condition for curvlinear grid
taw
taw is on a distinguished road
Dear fellows,
I am desperate for assistance please!!
I converted my FV Cartesian code for incompressible (primitive variable) Navier-Stokes solver to a general boundary fitted curvilinear coordinate system, written in a strong conservative form, with the physical velocity being directly solved.
I spend about 15 days on that and I am certain I did right on evaluating the metrics of the Jacobean (transformation matrix), the volume flux and pressure correction, etc. For instance I calculated the Jacobean as ja_i^j=\partial x_i/\partial \zeta_i; I find the area of the cell faces a_i^j=transpose(inverse(ja_i^j)).
I bench marked the code for rectangular grid using Ghia82 driven cavity flow. It works ok up to this.
Now I have some problem implementing Dirichlet boundary condition, trying to reproduce the skewed driven cavity problem.
I assume U1=A11*u1+A21*u2, U2=A12*uf1+A22*uf2, etc. with Ui and ufi being the volume flux and physical velocities at the faces of the cells respectively. For start I evaluated the cell face velocities using centered averages from consecutive grids, ie uf1=0.5(u1_i+u1_i+1), etc.
In many papers I came across, they don't discuss how to implement the bc, and I thought it is trivial. So I set u1=u2=0 at bottom , left and right faces of the cavity, u1=1, v1=0 at the top face.
But the result I got is different with Demirdzic92. I exhausted all avenues to find where I went wrong, with no avail.
By the way I used CDS and 2nd order UW (SOU) for the diffusive and convective and Rhie-chow for velocity/pressure coupling (collocated grid), in a fractional step manner. Since I tested this with Ghia I believe they are properly implemented
Can someone shade a light on this. I suspect I am stuffed with implementing the BC. For instance do we need to explicitly specify a BC for the corners. Normally, I don not set separate BC for the corners, since as the grid get refined the singularity from the corner fades away.
With best regards,
taw
taw is offline   Reply With Quote
Old   February 5, 2010, 07:03
Default any suggestion from those online now
taw
apology for the urgency; can some one suggest an explanation.
Old   February 5, 2010, 17:23
taw
I think I figured out the problem. The continuity equation (cell face velocities) bc was the problem. I should have set one extra grid line to zero for vf_i, unlike the centre velocities bc, since the computational molecule with Rhie-chow is large. Or one sided differencing should have been implemted for the boundaries.
One more correction
a_i^j=transpose(cofactor(ja_i^j)).
Regards, TAW
boundary conditions, boundary fitted, curvilinear coordinate
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
SymmetryPlane Boundary Condition raytracer OpenFOAM Running, Solving & CFD 0 July 11, 2008 17:04
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
