March 3, 2004, 14:38 |
Delta form of equations.
What is the advantage of using a delta form of equation and where could I find more information on this.
thanks. |
March 3, 2004, 21:01 |
Re: Delta form of equations.
Dear Unknown...
Please inform us what equation do you mean? |
March 4, 2004, 00:29 |
I remeber that the advance of a delta form discrete matrix equation is the independence of steady state solution on time step. T. H. Pulliam's book may contain it as well as in other CFD books.
March 4, 2004, 01:16 |
Delta form... Is this Dirac delta-function or something else?
March 4, 2004, 09:05 |
In the delta form of the equations you are solving for the incremental change of the dependent variables. For example you can write a second-order time difference as
du/dt = (3u(n+1 - 4u(n) + u(n-1)/2dt or du/dt = 1.5*(du(n+1) - (1/3)*du(n))/dt where du(n+1) = u(n+1) - u(n), du(n) = u(n) - u(n-1). It's the same equation, but the delta form is better behaved because typically the delta quantities are small changes and the resulting equations are more robust. |
March 4, 2004, 11:30 |
Thanks. I probably used such delta form when solved Poisson's equation for increment of pressure. This is one of steps in SIMPLE-method.
March 8, 2004, 07:46 |
Can you provide some reference. Thanks Apurva |
Delta form of Heat, Euler and NS equations | RameshK | Main CFD Forum | 3 | May 30, 2012 10:41 |
natural convection equations in non-dimensional form | Ehsan Khalili | FLUENT | 7 | April 29, 2012 21:06 |
strong conservation form of eulers equations | Dahyalal Bhate | Main CFD Forum | 0 | September 5, 2002 18:22 |
Equations in full form | Mark Render | Main CFD Forum | 3 | June 20, 2000 15:05 |
Crank-Nicolson technique for Conservation form of equations | Yogesh Talekar | Main CFD Forum | 2 | July 20, 1999 01:45 |
