CG, BICGSTAB(2) : problem with matrix operation and boundary conditions
Old   February 12, 2010, 04:34
Default CG, BICGSTAB(2) : problem with matrix operation and boundary conditions
moomba's Avatar
moomba is on a distinguished road
Hi
I am trying to develop a Parallel Conjugate Gradient (CG) and a Parallel BICGSTAB(2) to solve Dynamic Pressure in a Low Mach DNS solver. I have been using the Van der Vorst paper.
The system is working well with perdiodic boundary conditions, but fails to work with Neumann (dP/dxn = 0, converge but bad solution) and Dirichlet (P=constant, do not converge).
Because the problem is exactly the same for both system, I think it comes from the matrix multiplication.
Could someone explain me where I made a mistake ? Here is my fortran 90 code for the BICGSTAB(2).
The subroutine "Matrix_A_Multiply" is made here for periodicity on x1 and x2. The code is of course not optimised yet.
      module BICGSTAB_2
      use typegrid
      contains
      subroutine BICGSTAB_2_CORE(Grid,b,x)
      implicit none
      type (grid_type) :: Grid
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(in) :: b
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(out) :: x
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)) :: xx0
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)) :: u,v,r,s,t,w
      real(8) :: omega_1,omega_2,rho_1,rho_0,mu,nu,beta,gam,tau,alpha
      integer :: i
      xx0 = 0.0d0
      CALL Matrix_A_Multiply(Grid,xx0,r) ! (x_in,x_out) --> x_out = A * x_in
      r(:,:,:)  = b(:,:,:) - r(:,:,:)
      rho_0    = 1.0d0
      u(:,:,:) = 0.0d0
      alpha    = 0.0d0
      omega_2     = 1.0d0
      do i=0,1000,2
         rho_0 = - omega_2 * rho_0
         ! Even BiCG step :
         rho_1 = Scalar_Product(Grid,r,r)
         beta = alpha * rho_1 / rho_0
         rho_0 = rho_1
         u(:,:,:) = r(:,:,:) - beta * u(:,:,:)
         CALL Matrix_A_Multiply(Grid,u,v)
         gam = Scalar_Product(Grid,v,r) ! return v(1)*r(1) + v(2)*r(2) + v(3)*r(3) + ... + v(n)*r(n)
         alpha = rho_0 / gam
         r(:,:,:) = r(:,:,:) - alpha * v(:,:,:)
         CALL Matrix_A_Multiply(Grid,r,s)
         x(:,:,:) = x(:,:,:) + alpha * u(:,:,:)
         ! Odd BiCG step :
         rho_1 = Scalar_Product(Grid,r,s)
         rho_0 = rho_1
         v(:,:,:) = s(:,:,:) - beta * v(:,:,:)
         CALL Matrix_A_Multiply(Grid,v,w)
         gam = Scalar_Product(Grid,w,r)
         alpha = rho_0 / gam
         s(:,:,:) = s(:,:,:) - alpha * w(:,:,:)
         CALL Matrix_A_Multiply(Grid,s,t)
         ! GCR(2)-part :
         omega_1 = Scalar_Product(Grid,r,s)
         mu = Scalar_Product(Grid,s,s)
         nu = Scalar_Product(Grid,s,t)
         tau = Scalar_Product(Grid,t,t)
         omega_2 = Scalar_Product(Grid,r,t)
         tau = tau - ( nu * nu / mu )
         omega_2 = ( omega_2 - nu * omega_1 / mu ) / tau
! OPTI ?
         omega_1 = ( omega_1 - nu * omega_2 ) / mu
         x(:,:,:) = x(:,:,:) + omega_1 * r(:,:,:) + omega_2 * s(:,:,:) + alpha * u(:,:,:)
         r(:,:,:) = r(:,:,:) - omega_1 * s(:,:,:) - omega_2 * t(:,:,:)
         ! test of convergence
         if( max( ABS(maxval(r)) , ABS(minval(r)) ) < 1e-10 ) then
            print *,"Converged in",i,"iterations"
            return
         end if
         u(:,:,:) = u(:,:,:) - omega_1 * v(:,:,:) - omega_2 * w(:,:,:)
      end do
      print *,"ERROR, BICGSTAB(2) not converged"
      end subroutine BICGSTAB_2_CORE
      subroutine Matrix_A_Multiply(Grid,p,q)
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(in) :: p
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(out) :: q
      real(8), dimension(0:Grid%Nx(1)+1,0:Grid%Nx(2)+1) :: pl
      real(8), dimension(1:3) :: SDx
      integer :: i,j,n
      pl=77.0
      pl(1:Grid%Nx(1),1:Grid%Nx(2)) = p(1:Grid%Nx(1),1:Grid%Nx(2),1)
! Opti to be made
      pl(           0,1:Grid%Nx(2)) = pl(Grid%Nx(1)-1,1:Grid%Nx(2))
      pl(Grid%Nx(1)+1,1:Grid%Nx(2)) = pl(           2,1:Grid%Nx(2))
      pl(1:Grid%Nx(1),           0) = pl(1:Grid%Nx(1),Grid%Nx(2)-1)
      pl(1:Grid%Nx(1),Grid%Nx(2)+1) = pl(1:Grid%Nx(1),           2)
      do n=1,2
         SDx(n)=(-1.0/(Grid%h(n)*Grid%h(n)))
      end do
      do j=1,Grid%Nx(2)
         do i=1,Grid%Nx(1)
            q(i,j,1)=SDx(1)*(-pl(i-1,j)-pl(i+1,j)+2.0*pl(i,j)) +     &
            &        SDx(2)*(-pl(i,j-1)-pl(i,j+1)+2.0*pl(i,j))
         end do
      end do
      return
      end subroutine Matrix_A_Multiply
      function Scalar_Product(Grid,x1,x2)
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(in) :: x1,x2
      real(8) :: Scalar_Product
      integer :: i,j,k
      Scalar_Product=0.0d0
      do k=1,Grid%Nx(3)
         do j=1,Grid%Nx(2)
            do i=1,Grid%Nx(1)
               Scalar_Product = Scalar_Product + x1(i,j,k) * x2(i,j,k)
            end do
         end do
      end do
      return
      end function Scalar_Product
      end module BICGSTAB_2
In fact, for periodicity on x1, I copy point pl(Nx(1)-1) in ghost pl(0), and the point pl(2) in ghost pl(Nx(1)+1).
For Neumann dP/dxn=0, I copy point pl(1) in ghost pl(0), and pl(Nx(1)) in ghost pl(Nx(1)+1).
And for dirichlet P=0 on Nx(1) for example, I put pl(Nx(1))=0 and the output q(Nx(1))=0.
I of course made a mistake, but where
moomba is offline   Reply With Quote
Old   February 12, 2010, 18:47
moomba's Avatar
I made the problem far more simple : a GC to solve f=x² on [0,1] with Dirichlet on x (0 at x=0, and 1 at x=1 ), and with dp/dy=0 on y border :
Main :
      program Main
      use typegrid
      use CG
      implicit none
      real(8), allocatable :: F(:,:),P(:,:)
      real(8) :: PI,xx,yy
      integer :: i,j
      PI=3.141592653589793
      Grid%Ndim=2
      Grid%Nx(1)=100
      Grid%Nx(2)=100
      Grid%Nx(3)=1
      Grid%h(1)=1.0/(Grid%Nx(1)-1)
      Grid%h(2)=1.0/(Grid%Nx(2)-1)
      Grid%h(3)=0.0
      ALLOCATE(F(1:Grid%Nx(1),1:Grid%Nx(2)),P(1:Grid%Nx(1),1:Grid%Nx(2)))
      F(:,:)=2.0
      open(10,file="GC0.dat")
         do i=1,Grid%Nx(1)
            do j=1,Grid%Nx(2)
               Write(10,*)(i-1)*Grid%h(1),(j-1)*Grid%h(2),F(i,j)
            end do
         end do
      close(10)
      CALL CG_CORE(Grid,F,P)
      open(10,file="GC1.dat")
         do i=1,Grid%Nx(1)
            do j=1,Grid%Nx(2)
               xx=(i-1)*Grid%h(1)
               yy=(j-1)*Grid%h(2)
               Write(10,*)(i-1)*Grid%h(1),(j-1)*Grid%h(2),P(i,j)
            end do
         end do
      close(10)
      DEALLOCATE(F,P)
      end program Main
GC :
      module CG
      use typegrid
      integer :: n01,n11,n02,n12
      contains
      subroutine CG_CORE(Grid,b,x)
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(in) :: b
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(out) :: x
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)) :: r,p,q,xx0
      real(8) :: rho,rhop1,beta,alpha,res
      integer :: i
      n01 = 2
      n11 = Grid%Nx(1)-1
      n02 = 1
      n12 = Grid%Nx(2)
      xx0(n01:n11,n02:n12) = 0.0d0
      r(n01:n11,n02:n12) = b(n01:n11,n02:n12) - r(n01:n11,n02:n12)
      p(n01:n11,n02:n12) = 0.0d0
      beta = 0.0d0
      rho = Scalar_Product(Grid,r,r) ! return v(1)*r(1) + v(2)*r(2) + v(3)*r(3) + ... + v(n)*r(n)
      do i=1,1000
         p(n01:n11,n02:n12) = r(n01:n11,n02:n12) + beta * p(n01:n11,n02:n12)
         CALL Matrix_A_Multiply(Grid,p,q)
         alpha = rho / Scalar_Product(Grid,p,q)
         x(n01:n11,n02:n12) = x(n01:n11,n02:n12) + alpha * p(n01:n11,n02:n12)
         r(n01:n11,n02:n12) = r(n01:n11,n02:n12) - alpha * q(n01:n11,n02:n12)
         res = Residut(Grid,r)
         if( res < 1e-6 ) then
            print *, "GC converged in",i,"IT with a residut of",res
            return
         end if
!         print *,res
         rhop1 = Scalar_Product(Grid,r,r)
         beta = rhop1 / rho
         rho = rhop1
      end do
      print *,"ERROR, CG not converged"
      end subroutine CG_CORE
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(in) :: p
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(out) :: q
      real(8), dimension(0:Grid%Nx(1)+1,0:Grid%Nx(2)+1) :: pl ! copy with ghost, not optimized
      integer :: i,j,n
      pl=77.0 ! dummy value
      pl(1:Grid%Nx(1),1:Grid%Nx(2)) = p(1:Grid%Nx(1),1:Grid%Nx(2))
      ! Dirichlet : 0 en x=0, et 1 en x=1
      pl(         1,1:Grid%Nx(2)) = 0.0!((         1-1)*Grid%h(1))**2
      pl(Grid%Nx(1),1:Grid%Nx(2)) = 1.0!((Grid%Nx(1)-1)*Grid%h(1))**2
      ! Neumann dp/dn = 0
      pl(1:Grid%Nx(1),           0) = pl(1:Grid%Nx(1),         1)
      pl(1:Grid%Nx(1),Grid%Nx(2)+1) = pl(1:Grid%Nx(1),Grid%Nx(2))
      do n=1,2
         SDx(n)=(1.0d0/(Grid%h(n)*Grid%h(n)))
      end do
      do j=n02,n12
         do i=n01,n11
            q(i,j) = SDx(1)*(pl(i-1,j)+pl(i+1,j)-2.0d0*pl(i,j)) +     &
            &        SDx(2)*(pl(i,j-1)+pl(i,j+1)-2.0d0*pl(i,j))
         end do
      end do
      return
      function Residut(Grid,r)
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(in) :: r
      real(8) :: Residut
      integer :: i,j
      Residut=0.0d0
      do j=n02,n12
         do i=n01,n11
            Residut = max ( Residut, ABS(r(i,j)) )
         end do
      end do
      return
      end function Residut
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2)), intent(in) :: x1,x2
      integer :: i,j
      do j=n02,n12
         do i=n01,n11
            Scalar_Product = Scalar_Product + x1(i,j) * x2(i,j)
         end do
      end do
      return
      end module CG
Type Grid :
      module typegrid
      implicit none
         type grid_type
         integer                     :: Ndim
         integer                     :: NPL
         integer, dimension(1:3)     :: Nx
         real, dimension(1:3)        :: X0
         real, dimension(1:3)        :: Lx
         real, dimension(1:3)        :: h
         real, dimension(1:100,1:3)  :: XP
         end type grid_type
      end module typegrid
The CG do not converge, however the result is really near the solution :
As you can see, the value is a little different near x=1...
Does anyone have an idée ? It would really help me
Old   February 17, 2010, 03:37
moomba's Avatar
Problem solve, here are the sources if it can help someone.
It is a simple conjugate gradient with neumann, periodic and dirichlet boundary conditions.
! Neumann at face 1.1
BoundCG(1,1) = 1
! Dirichlet at face 1.2
 BoundCG(1,2) = -1
 PRES(Grid%Nx(1),:,:) = 0.0d0
! periodic on axe y
 BoundCG(2,1) = 12
 BoundCG(2,2) = 12
 CALL CG_CORE(Grid,PRES,BoundCG)
      module CG
      use typegrid
      contains
      subroutine CG_CORE(Grid,b,BoundCG)
      use commonGC
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(inout) :: b
      integer, dimension(1:3,1:2), intent(in) :: BoundCG
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)) :: r,p,q,w
      real(8) :: rho,rhop1,beta,alpha,res,a
      integer :: i,n
!     BoundCG
!     10 = simple com
!     12 = periodic com
!     1 = inflow (dP/dn = 0)
!     -1 = outflow (P = fixed)
      ! Dirichlet Boundary Conditions, set fixed value in initial guess, this values will not be overwritten during the CG process
      if(BoundCG(1,1) == -1) x(1,:,:) = b(1,:,:)
      if(BoundCG(1,2) == -1) x(Grid%Nx(1),:,:) = b(Grid%Nx(1),:,:)
      if(Grid%ndim > 1) then
         if(BoundCG(2,1) == -1) x(:,1,:) = b(:,1,:)
         if(BoundCG(2,2) == -1) x(:,Grid%Nx(2),:) = b(:,Grid%Nx(2),:)
      end if
      if(Grid%ndim > 2) then
         if(BoundCG(3,1) == -1) x(:,:,1) = b(:,:,1)
         if(BoundCG(3,2) == -1) x(:,:,Grid%Nx(3)) = b(:,:,Grid%Nx(3))
      end if
      CALL Matrix_A_Multiply(Grid,x,r,BoundCG) ! (x_in,x_out) --> x_out = A * x_in
      ! Dirichlet Boundary Conditions, set residut at 0.0 (value is already correct)
      if(BoundCG(1,1) == -1) r(1,:,:) = 0.0d0
      if(BoundCG(1,2) == -1) r(Grid%Nx(1),:,:) = 0.0d0
         if(BoundCG(2,1) == -1) r(:,1,:) = 0.0d0
         if(BoundCG(2,2) == -1) r(:,Grid%Nx(2),:) = 0.0d0
      end if
         if(BoundCG(3,1) == -1) r(:,:,1) = 0.0d0
         if(BoundCG(3,2) == -1) r(:,:,Grid%Nx(3)) = 0.0d0
      end if
      p(:,:,:) = 0.0d0
      beta = 0.0d0
      ! PRECONDITIONNEMENT
      do n=1,Grid%ndim
      end do
      a=1.0d0/(-2.0d0*SDx(1)-2.0d0*SDx(2))
      w(:,:,:) = a * r(:,:,:)
      rho = Scalar_Product(Grid,r,w) ! return v(1)*r(1) + v(2)*r(2) + v(3)*r(3) + ... + v(n)*r(n)
      do i=1,2000
         p(:,:,:) = w(:,:,:) + beta * p(:,:,:)
         CALL Matrix_A_Multiply(Grid,p,q,BoundCG)
         x(:,:,:) = x(:,:,:) + alpha * p(:,:,:)
         r(:,:,:) = r(:,:,:) - alpha * q(:,:,:)
            b(:,:,:) = x(:,:,:)
            return
         end if
!         print *,res
         rhop1 = Scalar_Product(Grid,r,w)
         beta = rhop1 / rho
         rho = rhop1
      end do
      subroutine Matrix_A_Multiply(Grid,p,q,BoundCG)
      implicit none
      real(8), dimension(0:Grid%Nx(1)+1,0:Grid%Nx(2)+1,0:Grid%Nx(3)+1) :: pl ! copy with ghost, not optimized
      integer :: i,j,n
      pl=77.0
      pl(1:Grid%Nx(1),1:Grid%Nx(2),1) = p(1:Grid%Nx(1),1:Grid%Nx(2),1)
      ! Neumann Boundaries, dP/dn = 0 , not optimized (should not copy, but simply not compute)
      if(BoundCG(1,1) == 1) pl(0,:,:) = pl(2,:,:)
      if(BoundCG(1,2) == 1) pl(Grid%Nx(1)+1,:,:) = pl(Grid%Nx(1)-1,:,:)
         if(BoundCG(2,1) == 1) pl(:,0,:) = pl(:,2,:)
         if(BoundCG(2,2) == 1) pl(:,Grid%Nx(2)+1,:) = pl(:,Grid%Nx(2)-1,:)
      end if
         if(BoundCG(3,1) == 1) pl(:,:,0) = pl(:,:,2)
         if(BoundCG(3,2) == 1) pl(:,:,Grid%Nx(3)+1) = pl(:,:,Grid%Nx(3)-1)
      end if
      ! Periodic Boundaries
      if(BoundCG(1,1) == 12) pl(0,:,:) = pl(Grid%Nx(1)-1,:,:)
      if(BoundCG(1,2) == 12) pl(Grid%Nx(1)+1,:,:) = pl(2,:,:)
         if(BoundCG(2,1) == 12) pl(:,0,:) = pl(:,Grid%Nx(2)-1,:)
         if(BoundCG(2,2) == 12) pl(:,Grid%Nx(2)+1,:) = pl(:,2,:)
      end if
         if(BoundCG(3,1) == 12) pl(:,:,0) = pl(:,:,Grid%Nx(3)-1)
         if(BoundCG(3,2) == 12) pl(:,:,Grid%Nx(3)+1) = pl(:,:,2)
      end if
      do n=1,2
         SDx(n)=(1.0/(Grid%h(n)*Grid%h(n)))
      end do
      do j=1,Grid%Nx(2)
         do i=1,Grid%Nx(1)
            q(i,j,1)=SDx(1)*(pl(i-1,j,1)+pl(i+1,j,1)-2.0*pl(i,j,1)) +     &
            &        SDx(2)*(pl(i,j-1,1)+pl(i,j+1,1)-2.0*pl(i,j,1))
         end do
      end do
      ! Dirichelt boundaries, set q at 0 (to not alter the x fixed value)
      if(BoundCG(1,1) == -1) q(1,:,:) = 0.0d0
      if(BoundCG(1,2) == -1) q(Grid%Nx(1),:,:) = 0.0d0
         if(BoundCG(2,1) == -1) q(:,1,:) = 0.0d0
         if(BoundCG(2,2) == -1) q(:,Grid%Nx(2),:) = 0.0d0
      end if
         if(BoundCG(3,1) == -1) q(:,:,1) = 0.0d0
         if(BoundCG(3,2) == -1) q(:,:,Grid%Nx(3)) = 0.0d0
      end if
      return
      implicit none
      real(8), dimension(1:Grid%Nx(1),1:Grid%Nx(2),1:Grid%Nx(3)), intent(in) :: r
      real(8) :: Residut
      integer :: i,j,k
      Residut=0.0d0
      do k=1,Grid%Nx(3)
         do j=1,Grid%Nx(2)
            do i=1,Grid%Nx(1)
               Residut = max ( Residut, ABS(r(i,j,k)) )
            end do
         end do
      end do
      return
      implicit none
      integer :: i,j,k
      do k=1,Grid%Nx(3)
         do j=1,Grid%Nx(2)
            do i=1,Grid%Nx(1)
            end do
         end do
      end do
      return
      end module CG
module commonGC
   implicit none
   real(8), allocatable, dimension(:,:,:), save :: x
end module commonGC
If used, you need to allocate x, and set it to 0.0 before the first time you use the routine, because the CG use the last solution calculated at the previous time as initial guess.
This program is not very efficient, but it is simple and a may help to start with CG.
With my best regards
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 01:20
Problem with boundary file pvc OpenFOAM Bugs 0 June 11, 2007 08:56
