February 21, 2010, 02:02 |
Definition of Nusselt Number
Chandra
Rep Power: 16 |
Hi, I have a heated flat-surface with water running over it parallely....a sort of forced convection.
The fluid water is assumed to have its physical properties varying with temperature, i.e. density, thermal conductivity etc. are temperature dependent. To define the local Nusselt number at a position "x", what temperature should be appropriate for evaluation of the fluid properties? Should it be the wall temperature T(x). Or, should it be the film temperature Tf(x), which is an average of the wall temperature T(x) and the far-field temperature T_infinity(x)? In short: Nu(x) = h(x) * x / k(x). k(x) = Thermal conductivity at location x = k(T(x)). T(x) = T_solid(x) or 0.5*[T_solid(x) + T_infinity(x)] ? Thanks! Last edited by shekharc; February 21, 2010 at 02:07. Reason: not well formated |
fluid properties, nusselt number, temperature dependence |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
