Boundary Layer thickness
Old   March 4, 2010, 08:10
Default Boundary Layer thickness
robinfisichella is on a distinguished road
I have a CFD model and i am trying to improve the density of the mesh inside the BL via additional prism layers. One thing i want to know is how thick (aproximately) the BL is so i can calculate how many layers i need.
Does anyone know a way of estimating the thickness of the BL?
Cheers
robinfisichella is offline   Reply With Quote
Old   March 4, 2010, 09:31
otd
private
otd is on a distinguished road
Most introductory heat transfer texts have chapters on how boundary layer models are developed starting with the Navier-Stokes equations. These eventually lead to algebraic expressions for b. l. thickness as a function of Reynolds Number or other appropriate dimensionless groupings of fluid properties, physical dimensions, and driving functions.
On my shelf of (antique) heat transfer texts are Schlichting (Boundary Layer Theory) and Chapman, (Heat Transfer). Others will be able to point to modern (and thus easier to find) texts.
Good luck!
otd is offline   Reply With Quote
Old   March 5, 2010, 06:48
Default BL Thickness
Ianto is on a distinguished road
If you're using commercial software try the user manual - CFX's details calculations for Y+ and B.L. thickness under "turbulence and near wall modelling".
Good luck.
Ianto
Ianto is offline   Reply With Quote
Old   April 29, 2010, 00:06
E Busquets
Enrique Busquets is on a distinguished road
The way on which I usually calculate the boundary layer is:
δ=5.2x/√Re
Enrique Busquets is offline   Reply With Quote
Old   April 30, 2010, 10:10
Default 3 dimensional wing with winglet design Using Catia
turwidi buwang
le bien aime is on a distinguished road
hello, I am in problem in Design wing with winglet using catia. I have design 3 dimensional wing with taper, sweep ang twist. But i cant design winglet on the tip. I will analize the design with Fluent. Anyone could help me....
le bien aime is offline   Reply With Quote
Old   August 21, 2011, 06:28
Default empirical formula for B.L. thickness?
Courant is on a distinguished road
I'd like to know boundary layer thickness around an airfoil (for ex. NACA 0012), I can use http://www.mh-aerotools.de/airfoils/javafoil.htm but the only result it can display are:
v/V: normalized surface velocity
d1: displacement thickness
d2: momentum loss thickness
d3: energy loss thickness
Cfl: ocal friction coefficient
H12: shape factor d1/d2
H32: shape factor d3/d2
flow state: laminar, turbulent, separated
y1: the first cell height required for y+=1 (multiplied by 100 resp. in %) value useful for grid generation
how can I calculate Boundary Layer thickness from any of these quantities?
or is there a semi-empirical formula to calculate it for an airfoil like the one posted above?
δ=5.2x/√Re
Courant is offline   Reply With Quote
Old   August 23, 2011, 15:27
up; maybe I should have opened another topic
boundary layer thickness Lee,jangho FLUENT 5 January 5, 2017 10:03
Boundary layer thickness ghazanfarzahedi Main CFD Forum 2 July 28, 2009 23:43
Boundary layer thickness calculation nat FLUENT 0 April 9, 2009 06:04
plotting boundary layer thickness graphs in a 3d Neelima FLUENT 1 March 29, 2006 18:04
Boundary Layer Thickness cfd-freak Main CFD Forum 3 March 27, 2003 12:18
