Supersonic combustion
Old   August 7, 2010, 10:13
Default Supersonic combustion
Roshan S Lal
Roshanlal is on a distinguished road
Hi friends
I'm trying to model a supersonic reacting flow with crosswise injection of hydrogen gas at mach 1 into mach 2.5 main air stream. I'm using finite rate combustion model with the fluent 6.3 solver
I want to find the combustion efficieny. And in the papers its given as
ηc = 1 – [ ∫αρu dA / ∑m fuel in ] ; α = mass fraction of fuel
How to evaluate this formula with fluent reports. Should I find the term ∫αρu dA by surface integral and flow rate with α as the variable. Is there any other means to get efficiency of combustion
Roshan
Roshanlal is offline   Reply With Quote
Old   August 28, 2010, 21:13
aditya
hello2ap is on a distinguished road
Originally Posted by Roshanlal View Post
Hi friends
Roshan
can u tell me which method u r using for combustion
hello2ap is offline   Reply With Quote
Old   August 29, 2010, 00:41
Roshan S Lal
I ve mentioned it - FINITE RATE MODEL is being used for the supersonic combustion
Old   August 29, 2010, 19:59
aditya
thanks friend but which one premixed or non pre mixed model
Old   August 29, 2010, 20:10
aditya
can u give me any supersonic combustion releted paper or case data file of combustion i highly appreciated you. thanks.
hello2apsingh@gmail.com
actually i have tried many time but till now i am not success in supersonic combustion plz help me thanks
Old   August 31, 2010, 11:45
Roshan S Lal
Yar I'm also trying to get the solution but not succeeded yet. But i think as far as supersonic simulation is concerned, U need to use density based solver. The models u mentioned is applicable for pressure based one, ie not supersonic
Old   September 2, 2010, 01:45
aditya
if we are using density based and taking air as ideal gas and if we using finite rate /eaddy dissipation model it shows only mixing and not burning of the fuel. and after some changes it show turbulence viscosity limited or absolute pressure critical.
have u done on any supersonic combustion kilnly help me
thanks
Old   September 3, 2010, 05:55
Roshan S Lal
hi how do u know that it gives mixing only? i think when reaction is enabled there is the possibility of starting combustion, provided it has enough temperature to start reactions. i want to know how should i ascertain that burning had occured??
i'm doing work on cavity. Using this way i got enough mass fration of pdt of combustion, H2O. but it is not happening in the regions as seen in the literature. I have also the same doubt wheather combustion modelling is not the proper one. Yar if this is not the way then what can be ?? Help plz
Old   March 16, 2011, 05:52
aditya
hello If any one need help regarding any combustion model supersonic or hypersonic or subsonic,2d les modeling or 3d. write to me at hello2apsingh@gmail.com
Thanks
Supersonic Combustion Andrew FLUENT 1 March 16, 2011 06:00
help in modelling supersonic combustion in Fluent omar.2002bh Main CFD Forum 1 March 16, 2011 05:58
2d supersonic combustion with H2 gas Roshanlal FLUENT 0 August 3, 2010 10:25
A supersonic combustion in a Laval nozzle argeus FLUENT 0 March 29, 2010 13:52
which combustion model can be in supersonic field cfdfans FLUENT 0 March 9, 2001 22:13
