Noise reduction in automobile muffler(silencer) using CFD |
January 9, 2010, 10:29 |
aniket
This is a B.E project.I'm using a resonator geometry(set of tubes with holes in them) for noise reduction.Is d analysis of such a geometry possible using CFD???
Also do the holes behave as wall only? Right now i know that only mass flow rate values can be given at inlet.What should be the inertia and viscous resistances values (if these can b d other parameters) at muffler inlet to obtain noise reduction after d muffler?? |
February 17, 2010, 11:54 |
#2 | |
February 24, 2010, 18:00 |
N/A
Rep Power: 17 |
You need to first decide on the time you have in hand and the computing power that you have. The holes you can model them as a cavity region. The more the complexity that you introduce, the uncertanities increases with them.
February 24, 2010, 21:22 |
Regarding analysis of muffler using cfd.
Sir,
Thank you so much for replying. We have got a geometry of a perforated pipe type of muffler that has been developed in CATIA V5 R17.. Can we import that file in GAMBIT and then create a mesh on it? If yes, then please guide us how? It is our final year B.E. project and we have time till March End. |
March 7, 2010, 02:34 |
Meshing perforated tube
aniket
how do v mesh a perforated tube.there r 3 perforated tubes inside the muffler body n 1 of the tube is vertical .so how can v use Cooper scheme for meshing....if not then which scheme should v use.
Drag Reduction and CFD | Daniel | Main CFD Forum | 3 | January 20, 2008 10:32 |
how to measure noise in CFD | viky | Main CFD Forum | 0 | August 14, 2006 09:21 |
is there any money in CFD? | T | Main CFD Forum | 35 | May 9, 2001 19:35 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 08:45 |
salary range | Frank Muldoon | Main CFD Forum | 7 | August 3, 1998 19:04 |
