calculation of Nu NO.
Old   March 16, 2010, 09:14
Default calculation of Nu NO.
m&s
raminj
m&s is on a distinguished road
hi every body,
how can I calculate nusselt number in a tube?
meanwhile all values for "convective heat transfer coefficient" (h) which I attempted for that were zero, is this value (zero) logical?
thanks for your attention.
m&s is offline   Reply With Quote
Old   March 16, 2010, 23:35
Hamid Zoka
Hamidzoka is on a distinguished road
describe your geometry and boundary conditions.
check if you have chosen adiabatic wall boundary conditions.
h is normally fucnction of both fluid and flow type.
Hamidzoka is offline   Reply With Quote
Old   March 17, 2010, 01:55
m&s
raminj
thank you Hamid
wall tempreture is constant and geometry is a rectangle and its boundry is velocity inlet,axymetric,wall and pressue outlet
how can i calculate nu number?
Old   March 17, 2010, 07:09
Hamid Zoka
Dear Ramin;
It seems that you are about to solve an axisymetric pipe flow with constant wall temperature. for such this case nusselt number is calculated as a function of Reynolds and Prandtl numbers for both laminar and turbulent flows and can be found in heat transfer text books. then, "h'"coefficient is calculated from nusselt number. in case pipe flow calculated formula for nusselt number is not applicable to your case, firstly you have to calculate "h" manually using energy equation at solid wall control surface like this:
Q(convective;fluid to solid)= Q(conductive;through the wall)
knowing h and k of fluid, nusselt will be calculated.
does it help?
Old   March 18, 2010, 01:44
m&s
raminj
thank you but i don't know how can i do this job.
please help me.
why fluent has surface nusslet number but doesn't have flouid nu number?
Old   March 18, 2010, 03:40
Hamid Zoka
Dear Ramin;
this is because of the definition of nesselt number:
"In heat transfer at a boundary (surface) within a fluid, the Nusselt number is the ratio of convective to conductive heat transfer across (normal to) the boundary."
in fact nusselt number is meaningless when there is no surface.
for more info. look at the following link:
http://en.wikipedia.org/wiki/Nusselt_number
does it help?
Propeller calculation toil CFX 15 May 22, 2017 04:06
How to continue calculation after the computer is abruptly shut off? superqtp CFX 5 September 25, 2012 08:53
The calculation efficiency of OpenFOAM chiven OpenFOAM Running, Solving & CFD 4 September 14, 2009 04:44
Warning 097- AB Siemens 6 November 15, 2004 04:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
