CFD by anderson, chp 10.... supersonic flow over flat plate |
March 25, 2010, 06:22 |
varun
hi all
i'm trying to write C code for supersonic flow over flat plate. i'm reffereing CFD by JD anderson chp 10. i have a few doubts hope u can help. firstly when i'm calculating vector E at plate surface and vector F at inflow, what should be the values of txy, txx, tyy, qx and qy, should i consider. should i take all of them to be zero...??? and after prdictor step, when calculating txy, then in one of the terms we need to calculate central difference, so our expression is something like.... U(i+1,j)-U(i-1,j) but we dont have values for U(i+1,j) at time step t+dt, right...??? so am i suppose to use the values calculated at previous time step.... coz that is the only way... jz needed to confirm.. thanks once again varun |
December 20, 2011, 04:30 |
Full code
Balaji Sankar
Sorry for the late reply. I am posting the full code in the attachment, in C. All functions are named as in Anderson. Takes 70 seconds. No input files. All parameters are defined in preprocessor part.. Has been verified using the temperature profile at the trailing edge. Hope this helps. Enjoy. |
December 20, 2011, 04:33 |
Balaji Sankar
Ooops. Didn't upload.
Here should be the code. |
February 16, 2012, 10:39 |
Thanks for the code
March 29, 2013, 07:26 |
Cean
thanks for c code.
August 14, 2013, 12:37 |
would you please send me a copy?
soroosh alahdin
Rep Power: 12 |
my email address is my username, if you decided to help, ofcourse.
April 3, 2013, 08:39 |
Cean
there is one little error in the code, see attached pic.
The second Redx should be Redy. |
April 29, 2013, 00:20 |
Thank you
Balaji Sankar
Hi Cean,
Thanks for pointing out the error! I don know how the plots came out fine after the mess up . Thanks again |
May 3, 2013, 03:49 |
Thanh
thank you so much
August 14, 2013, 16:34 |
sandy
Mr.Balaji ,
I tried compiling the code u gave without making any change in it . I just gave me errors . if possible take a look at this Code:
main.c: In function ‘main’: main.c:145:13: warning: passing argument 4 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 5 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 6 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 7 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 8 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 9 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 10 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 11 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 12 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c: At top level: main.c:443:6: warning: conflicting types for ‘verbose_mac’ [enabled by default] main.c:140:13: note: previous implicit declaration of ‘verbose_mac’ was here main.c:1175:6: warning: conflicting types for ‘u2fp’ [enabled by default] main.c:318:5: note: previous implicit declaration of ‘u2fp’ was here /tmp/ccbyCj1V.o: In function `mac': main.c:(.text+0xbe8): undefined reference to `pow' main.c:(.text+0xe9c): undefined reference to `sqrt' main.c:(.text+0xf68): undefined reference to `sqrt' /tmp/ccbyCj1V.o: In function `verbose_mac': main.c:(.text+0x19d2): undefined reference to `pow' main.c:(.text+0x1aca): undefined reference to `sqrt' main.c:(.text+0x1b96): undefined reference to `sqrt' /tmp/ccbyCj1V.o: In function `fp2u': main.c:(.text+0x2b45): undefined reference to `pow' main.c:(.text+0x2b86): undefined reference to `pow' /tmp/ccbyCj1V.o: In function `fp2e': main.c:(.text+0x2cc9): undefined reference to `pow' main.c:(.text+0x2e9a): undefined reference to `pow' main.c:(.text+0x2ee1): undefined reference to `pow' /tmp/ccbyCj1V.o:main.c:(.text+0x31eb): more undefined references to `pow' follow collect2: error: ld returned 1 exit status sudharsan@ubuntu:~/Desktop$ gcc -lm main.c main.c: In function ‘main’: main.c:145:13: warning: passing argument 4 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 5 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 6 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 7 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 8 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 9 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 10 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 11 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c:145:13: warning: passing argument 12 of ‘mac’ from incompatible pointer type [enabled by default] main.c:69:6: note: expected ‘float *’ but argument is of type ‘float (*)[70][70]’ main.c: At top level: main.c:443:6: warning: conflicting types for ‘verbose_mac’ [enabled by default] main.c:140:13: note: previous implicit declaration of ‘verbose_mac’ was here main.c:1175:6: warning: conflicting types for ‘u2fp’ [enabled by default] main.c:318:5: note: previous implicit declaration of ‘u2fp’ was here /tmp/ccnpPswn.o: In function `mac': main.c:(.text+0xbe8): undefined reference to `pow' main.c:(.text+0xe9c): undefined reference to `sqrt' main.c:(.text+0xf68): undefined reference to `sqrt' /tmp/ccnpPswn.o: In function `verbose_mac': main.c:(.text+0x19d2): undefined reference to `pow' main.c:(.text+0x1aca): undefined reference to `sqrt' main.c:(.text+0x1b96): undefined reference to `sqrt' /tmp/ccnpPswn.o: In function `fp2u': main.c:(.text+0x2b45): undefined reference to `pow' main.c:(.text+0x2b86): undefined reference to `pow' /tmp/ccnpPswn.o: In function `fp2e': main.c:(.text+0x2cc9): undefined reference to `pow' main.c:(.text+0x2e9a): undefined reference to `pow' main.c:(.text+0x2ee1): undefined reference to `pow' /tmp/ccnpPswn.o:main.c:(.text+0x31eb): more undefined references to `pow' follow collect2: error: ld returned 1 exit status |
August 15, 2013, 09:49 |
math library?
#11 |
Balaji Sankar
Please google on "Linking math library while compiling c++ codes" . You basically add -lm option to your compile line so that the GCC can find power and absolute functions that are used in the code. PS: I had the same error few years ago Hope it helps |
August 20, 2013, 23:02 |
#12 | |
sandy
IT worked Mr.Balaji . How do i obtain the plots ? . Do i need to use any other software to plot ? . Thanks in advance |
August 20, 2013, 23:37 |
Plotting the output
#13 |
Balaji Sankar
Hi ,
Glad it helped you. You can use gnuplot for plotting results. A very small script will let you automate the plotting wonderfully. Its highly recommended for 2D plots. Quick way to get things done is to copy the pressure and temperature matrices into Matlab and do surface plots. This is how I did it long back. enjoy! |
August 20, 2013, 23:44 |
#14 | |
sandy
Thank you Mr.Balaji . I got the u_profile via gnuplot . I myself tried writing the entire thing in matlab . it did gave me results after 15000 iterations . But the results are slightly over predicted . Can you help me with this ? I am not a good programmer . |
August 21, 2013, 02:47 |
#15 | |
Cean
You could download it from here: https://sites.google.com/site/gmsh2s...edirects=0&d=1 Enjoy. |
May 11, 2018, 07:31 |
#16 |
ASHWANI MISHRA
August 15, 2013, 09:51 |
Code is there!
#17 |
Balaji Sankar
January 24, 2015, 22:43 |
#18 |
I encountered the following error~~~
Could you point out what is the problem? I use visual studio 2010 to compile it 1> Touching "Debug\navierStokes_anderson.unsuccessfulbuild ". 1>ClCompile: 1> main.cpp 1>d:\cfd\navierstokes_anderson\main.cpp(106): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(107): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(142): error C3861: 'verbose_mac': identifier not found 1>d:\cfd\navierstokes_anderson\main.cpp(147): error C2664: 'mac' : cannot convert parameter 4 from 'float [5][70][90]' to 'float *' 1> Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast 1>d:\cfd\navierstokes_anderson\main.cpp(211): warning C4305: '=' : truncation from 'double' to 'float' 1>d:\cfd\navierstokes_anderson\main.cpp(217): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(218): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(221): warning C4305: '=' : truncation from 'double' to 'float' 1>d:\cfd\navierstokes_anderson\main.cpp(227): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(228): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(231): warning C4305: '=' : truncation from 'double' to 'float' 1>d:\cfd\navierstokes_anderson\main.cpp(265): warning C4305: 'initializing' : truncation from 'double' to 'float' 1>d:\cfd\navierstokes_anderson\main.cpp(269): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(270): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(271): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(299): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(300): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(301): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(309): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(320): error C3861: 'u2fp': identifier not found 1>d:\cfd\navierstokes_anderson\main.cpp(328): error C3861: 'u2fp': identifier not found 1>d:\cfd\navierstokes_anderson\main.cpp(450): warning C4305: 'initializing' : truncation from 'double' to 'float' 1>d:\cfd\navierstokes_anderson\main.cpp(454): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(482): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(483): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(484): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(491): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(615): error C3861: 'u2fp': identifier not found 1>d:\cfd\navierstokes_anderson\main.cpp(681): error C3861: 'u2fp': identifier not found 1>d:\cfd\navierstokes_anderson\main.cpp(717): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(732): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(749): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(761): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(769): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(773): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(777): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(781): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(785): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(793): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(797): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(801): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(806): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(810): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(828): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(836): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(840): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(844): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(848): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(852): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(860): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(864): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(868): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(874): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(878): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(896): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(903): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(907): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(911): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(917): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(921): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(931): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(935): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(939): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(944): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(948): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(955): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(959): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(963): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(967): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(971): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(979): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(983): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(987): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(993): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(997): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1014): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1015): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1021): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1025): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1032): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1036): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1052): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1053): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1060): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1064): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1073): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1077): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1099): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1100): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1101): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1102): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1124): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1125): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1126): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1127): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1164): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1165): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1166): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1167): warning C4244: 'initializing' : conversion from 'double' to 'float', possible loss of data 1>d:\cfd\navierstokes_anderson\main.cpp(1188): warning C4244: '=' : conversion from 'double' to 'float', possible loss of data 1> 1>Build FAILED. 1> 1>Time Elapsed 00:00:00.16 ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== |
February 11, 2015, 09:47 |
Matlab code
#19 |
I have uploaded a Matlab code that solves the original problem in Anderson's book. It can be downloaded from MathWorks here: http://www.mathworks.com/matlabcentr...r-a-flat-plate Hope this helps!! |
Code for the book | Nishu | Main CFD Forum | 14 | April 19, 2017 07:33 |
Supersonic flow over flat plate | Nikhil | Main CFD Forum | 6 | May 20, 2013 12:48 |
supersonic flow past flat plate | shuo | Main CFD Forum | 0 | July 28, 2007 19:47 |
entrance of a flat plate | mc | Main CFD Forum | 0 | April 24, 2007 22:38 |
tricky flat plate laminar flow | sarat | FLUENT | 4 | September 9, 2005 18:35 |
