solver on unstructured triangles
Old   April 21, 2004, 08:17
Default solver on unstructured triangles
dominique
hi, i'm finalizing a 2D ns solver on unstructured tri-grid with fancy interpolations allowing for use of low quality meshes (yes, I get perfectly horizontal flow in a tube on crippled triangles). do you think it's worth making it into a C++ class and publishing it in some technical paper? when starting I couldnt find anything relevant that I could just take... thanks
Old   April 21, 2004, 22:56
Default Re: solver on unstructured triangles
Ananda Himansu
Most definitely, if a literature search shows no sign of the same scheme, you should publish it in a technical conference or journal paper. You should also investigate whether the scheme could handle only smooth solutions or does it also do a reasonable job resolving shock waves on low-quality triangular meshes.
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 19:41
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Unstructured Euler Solver John Main CFD Forum 3 September 6, 2007 15:34
unstructured VOF flow solver yann Main CFD Forum 1 November 13, 2002 04:07
