March 24, 2003, 08:45 |
Turbulent viscosity in Laminar Flow
I would like to know if a laminar flow (not potential flow), has got the turbulent or eddy viscosity? If the answer is yes, in which way I can compute it? Thank you Mike |
March 24, 2003, 08:52 |
Re: Turbulent viscosity in Laminar Flow
No. By definition a laminar flow has no turbulence. Eddy viscosity is a model for how turbulence works, and is computed using turbulence models, developed to simulate turbulent flows.
March 24, 2003, 08:57 |
Thank you!
Another question: is the eddy viscosity proportional with an another (non turbulent) quantity? I.e., the kinematic viscosity? |
March 24, 2003, 09:40 |
Have a look at pages 6-7 of the following link.
ftp://ftp.nist.gov/pub/bfrl/mcgratta...S/techman3.pdf I am sure this can help you. Steve |
April 10, 2010, 17:48 |
Santhosh
Rep Power: 16 |
Steve,
th link given by you is nt working anymore. Can you post an updated one. |
April 12, 2010, 08:56 |
Rep Power: 18 |
You do realize that the thread you resurrected is 7 years old, and Steve may not inhabit these fora anymore, don't you?
April 12, 2010, 09:04 |
#7 | |
Sydney Miles TEKAM
Rep Power: 16 |
Kinematic viscosity is a property of the flui. It remains constant in every area of most common flow. |
April 12, 2010, 09:21 |
Santhosh
Rep Power: 16 |
ooops..
I didnt realize, I thought the qn was still relevant today..! |
April 12, 2010, 11:40 |
turbulent flows
#9 |
Patrick Godon
Rep Power: 17 |
Eventhough the original post is 7 years old... I thought maybe someone might still be interested in that topics.. or for all others who might be interested... In a turbulent flow the size of the Eddies L can be as large as the size of the domain and the velocity of the eddies is as large as the change in the velocity over a distance L, so Vturb ~ V(x+L)-V(x) , such that the viscosity of the turubulence can be written
viscosity from tubulence ~ Vturb L Usually supersonic eddies dissipate quickly by shocks such that Vturb < Vsound . In the limit of small L, one can write Vturb = V(x+L)-V(x) = (dV/dx) L such that turbulent viscosity ~ L^2 (dV/dx) the turbulent viscosiity is proportional to the shear dV/dx |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Using a turbulent model when the flow is entirely laminar. | mwhyte | FLUENT | 1 | June 7, 2012 10:35 |
flow with high turbulent viscosity ratio | Phillips | Main CFD Forum | 2 | August 25, 2008 18:01 |
laminar and turbulent flow over a single airfoil. | Pablo Cornejo | FLUENT | 0 | August 30, 2005 17:57 |
Reynolds and Turbulent Flow | Frederic Dubinski | Main CFD Forum | 2 | October 20, 2004 13:57 |
