Equation in which coordinate system
Old   April 23, 2004, 02:38
Default Equation in which coordinate system
zubin
If I have to solve a flow problem for a cylindrical physical domain, in which coordinate system should I have the equations - rectangular cartesian or cylindrical coordinate? For example, if I want to study the natural convection problem for a fluid in a cylindrical container, should I write the NS and energy equations in cylindrical coordinate or can I write the equtions in cartesian coordinate ? For writing and solving the equations in cartesian coordinates for such situation, what are the consequences?
Old   April 23, 2004, 05:22
Default Re: Equation in which coordinate system
versi
Both Cylinderical and Cartesian systems are valid. But for treating BC, the former is obviously better.
Old   April 23, 2004, 05:23
Mihail Galabov
Cartesian coordinates are not adequate to the problem. If your flow has an axial symmetry you can make it two- dimensional or even one- dimensional if you use von Karman's method for integrating over the radius of the cylinder.
Old   April 23, 2004, 05:44
zubin
Mihail,
My question is general. I do not mean that exploiting some symmetry, etc., I can convert it to a one or two-D problem. My point is that if I write the equations for cartesian coordinates and solve them, what consequences (out of physics) are expected. For example, there are certain terms specific for the cylindrical coordinates which arise because of the problem definition and geometry itself. The 1/r term(s), e.g., has a meaning.
Old   April 23, 2004, 06:25
Mihail Galabov
Well, divergention and tension in Navier - Stokes equation don't look very friendly (something like 1/r(d(rVr)/dr)+1/r(d(Vfi)/dfi)+dVz/dz and so on) but it's worth trying it.
Old   April 23, 2004, 08:44
Praveen
If you are using finite differences on a cylindrical grid then you are forced to convert the equations to cylindrical coordinates.
If using a finite volume method on a cylindrical (or any other type of grid) you will obviously use the integral formulation of the equations.
Old   April 23, 2004, 11:35
noName
If you intend to solve NS in cylindrical-polar coordinates, you will start out by writing the equations in polar coordinates. Of course in addition to different looking terms, there will be *more* terms, like the centrifugal term for the radial momentum balance. Also note, coordinate transformations, (and other Galilean transformations) do not affect the physics represented by the flow equations.
Solving eqns. in cylindrical polar may not be that easy for a pipe because 1/r blows up. Can be done with special basis functions tho, if anyone is interested.
Old   April 23, 2004, 14:21
Kevin
If you can easily specify boundary conditions in cartesian coordinates, i think it's better to deal with this coordinate system : you don't have source terms and don't have singularity problem at symmetry axe. The 1/r before fluxes and the source term only arise because of the coordinates system change. There is not an "additional meaning" in the cylindrical coordinate formulation, i.e. all the terms are "include" in the cartesian formulation.
Old   April 30, 2004, 10:33
ma
good points of using cylindrical coordinates: (1) only two spacial variable (x, r) instead of three (x, y, z) in Cartesian coordinates. (2) as a consequence, you can save a lot of memory and run faster.
bad points: (1) extra source term (2) may encounter singularity at r=0.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
change coordinate system Nabil FLUENT 2 February 12, 2010 11:23
change coordinate system cartesian to cylindrical tht FLUENT 0 September 6, 2007 05:46
Multigrid method for cylindrical coordinate system chinthakindi Main CFD Forum 5 November 1, 2003 14:46
Coordinate System Pravesh kumar FLUENT 7 November 26, 2002 09:50
