transient pressure correction
Old   April 21, 2004, 12:47
Default transient pressure correction
dominique
hi,
i'm doing pseudo-compressibility pressure correction in transient low R_e flow in a tube (2D). how do I choose optimal ratio between dt for velocity update and (pseudo) dt for pressure correction? in particular: is it better to do more velocity corrections and few pressure corrections or vice versa?
thank you.
Old   April 22, 2004, 07:51
Default Re: transient pressure correction
vesi
If you are using pseudo-compressibility method, then pressure is also updated via time or pseudo time marching, then you do the same times of corrections to both V and P.
Old   April 22, 2004, 17:03
dominique
you mean, correct velocity, correct pressure and again, in a loop? yes, that is clear, but what about "dt", how do I set optimal relation between two delta t's for both explicit time marching...?
thanks domi
Old   April 23, 2004, 05:29
versi
Years Ago AIAA Journal had papers discussing pseudo time sep and physical time step. The pseuodtime step has the meaning of relaxation factor, it can be larger than a nondimensional physical Dt. may be 10 times up, I remebered. If the inner iteration is implicit can be 10^12 up. (== discarding it at all)
Old   April 23, 2004, 11:14
centaur_ks
read paper on dual time step approch , try one by Yoon and Jameson on LU-SSOR for eular and NS eqn and there are some more by Jameson that explains dual time stepping approch quite well.
Old   May 27, 2004, 08:03
Default Harlow & Amsden
enis
Hello everyone,
Is there anybody who are using IMF(Implicit Multifield Model of Harlow & Amsden) technique for their studies?I want to ask some questions.
thanks
Pressure correction equation,Ferziger and Peric Hooman Main CFD Forum 1 July 20, 2010 05:21
Pressure correction on SIMPLE Diego Nogueira Main CFD Forum 6 October 10, 2004 14:43
Transient pressure in conduit John Main CFD Forum 0 October 28, 2003 17:26
Pressure correction question - Please help! Barry Main CFD Forum 1 February 5, 2003 00:27
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
