C++ and FORTRAN
Old   May 31, 2004, 23:15
Default C++ and FORTRAN
Steve
Hi, I'm presently using Visual C++ to write and compile my code, but might need to convert to using FORTRAN. I heard from my senior that it is actually possible to use C++ code and compile under FORTRAN, or something like that. Is this possible? Or rather, is there any way for me to run my code under FORTRAN without changing my present C++ text to FORTRAN language? Thanks!!
Old   June 1, 2004, 00:44
Default Re: C++ and FORTRAN
Leo
You have to carry out the changes since you are using VC++. MS uses libraries that may not be available if you are using a fortran compiler from some other vendor. Under linux there is a utility available that can convert C code to Fortran. Intel has free fortran 90 compiler available for personal use.
Old   June 1, 2004, 00:58
Leo
Also, the sooner you stop using VC++, the better. Linux can handle such jobs better.
Old   June 1, 2004, 02:12
Steve
Ok, thanks for the advice, Leo
Old   June 1, 2004, 07:57
Tim
It is also possible to call a c subroutine from fortran (and vice versa) if thats any use to you?
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 15:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 09:34
