Flow at different temperatures
Old   May 19, 2010, 06:27
Default Flow at different temperatures
Carlos
Carlitos is on a distinguished road
Dear all,
i'm dealing with a multiphase transient model which contains two gas and a solid divided in tiny particles. The two gas are injected against the solid, which is contained in a kind of vessel, so the solid particles are drag with the flow.
I've ran the simulation at enviromental conditions as an isotermal process at 25 C and it works. The problem comes when the temperature of my isothermal problem is changed to 700 C instead of 25. The solver gets the solution but now it seems the solid particles are thrown out of the reactor and i don't understand it, because if the temperature rises its density goes down thus the drag force should be lower and consequently particles should NOT be able of reach the top of vessel, as in enviromental conditions simulation.
What do you suggest about it?. Any idea?
Thanks in advance
Carlitos
Carlitos is offline   Reply With Quote
Old   May 21, 2010, 08:49
hameurlaine
louiza is on a distinguished road
Hi carlos
how to introduce two energy equation in Fluent.
Thank you
louiza is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
