subsonic test case with heat transfer
Old   November 15, 2003, 13:48
Default subsonic test case with heat transfer
senthil
Hi All Iam looking for a subsonic test case with heat transfer for validating my code. Can anyone suggest some. A bit about code: It's an unstructured fully compressible code.
Thankx and regards Senthil
Old   June 14, 2010, 12:40
Default Sub-sonic test
Pavel Ryzhakov
Pavel_Ryzhakov is on a distinguished road
Look, you could try the test of a differentially heated cavity at high Grasshof number. They usually do it with the Boussinesq, but if you increase the temperature difference, the central vortex should be moving (due to flow expansion, a phenomenon that a Boussinesq-based solver cannot predict).. See papers of Mohamad and Viskanta. Another good test is summarized by Christon et al. (see 8:1 cavity benchmark)
Good luck!
Pavel_Ryzhakov is offline   Reply With Quote
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 13:14
test case for conjugate heat transfer Fab Main CFD Forum 2 July 9, 2008 02:49
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 06:33
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 14:36
