linearizing euler equation
Old   June 22, 2004, 13:34
Default linearizing euler equation
kalyan
Dear friends , I just entered into the concepts of CFD . I would like to know : Is there any method to linearize a nonlinear euler equation in conservative form (no source terms )? If so please provide me with an Example so as to implement the finite difference technique .
Old   June 22, 2004, 23:44
Default Re: linearizing euler equation
Praveen
It is a good excercise to carry out the calculations yourself. It is really simple. Write every quantity u as u = U + u' where U is a constant function. Plug this into the equations and neglect all terms which are of order O(u'*u') and above. The remaining terms will be linear in u' and its derivatives.
Old   June 23, 2004, 08:59
Apurva
Hi
Refer this two papers by Mike Giles:
D.R. Lindquist and M.B. Giles. `Validity of linearized unsteady Euler equations with shock capturing'. AIAA Journal, 32(1):46-53, 1994
M.S. Campobasso and M.B. Giles. `Stabilization of a linearized Navier-Stokes solver for turbomachinery aeroelasticity' in Computational Fluid Dynamics 2002. Springer-Verlag, 2003
You can get the copy of second paper from : http://web.comlab.ox.ac.uk/oucl/work.../journals.html
Hope it helps
Good Luck
Apurva
Old   June 23, 2004, 14:43
kalyan
thanks for the suggestions praveen & apurva .
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Euler ~Navier Stokes equation Khan Main CFD Forum 1 September 9, 2006 03:26
Linearized Euler Equation vasanth Main CFD Forum 0 May 30, 2004 15:25
