How to do turbulent bc on the injection slot?
Old   June 12, 2004, 01:32
Default How to do turbulent bc on the injection slot?
peter.zhao
I want to calculate that the N2 gas flow from slot at the wall injects transversely into the supersonic air main stream with K-Omega turbulence model, but I don't know how to deal with the bc on the injection slot for K-Omega turbulence model. All comments are welcomed! Thank you in advance.
Old   June 14, 2004, 09:02
Default Re: How to do turbulent bc on the injection slot?
javadi
hi. if the geometry of channel injection is defined then you can solve the channel of the jet injection with the main stram cross-flow and for the inlet of channel jet flow you can use uniform velocity profile your project is simillar of mine " compressible turbulent Jet Crossflow Interaction whith sevaral turbulence model(spc. k-e k-w and RSM)- application in gas turbine film-cooling smulation" i'm workinkg on this project since two yares ago
Old   June 14, 2004, 09:19
peter.zhao
How do you set the k and w at the exit of inject? I have found many paper don't make clear this question. One AIAA paper says the turbulent viscous coefficient eqaul to laminar viscous coefficient and k is set by the experiment; Wilcox gived a formula for w at the mass injection but no information for the turbulent viscous coefficient and turbulent kinetic energy K in his famous book "Turbulence modeling in CFD", 1998. Can you give me some information in detail?
Old   June 26, 2004, 07:05
javadi
if you solve the channel jet with the main stream flow simultaneously there is no need to enforce any boundary condition at jet exit.
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Problem in Turbulent modeling of impinging slot jet amirbabak1979 Main CFD Forum 5 October 29, 2009 21:00
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
sonic Jet in crossflow (slot injection), cfl no amol palekar Main CFD Forum 1 November 14, 2004 20:46
Turbulent Mass Injection Boundary Conditions B. Laubacher Main CFD Forum 6 October 16, 1999 11:56
