Inversion of large sparse linear systems
Old   June 23, 2010, 14:34
Default Inversion of large sparse linear systems
kostas
pankos is on a distinguished road
Can anyone tell me some libraries for C languange which inverts large sparse linear systems? It would be better if its install is for linux systems (gcc compiler).
pankos is offline   Reply With Quote
Old   June 23, 2010, 16:55
DoHander is on a distinguished road
GSL - GNU Scientific Library
Cblas
Clapack
and so on ... any Linux distribution should have the above.
Do
DoHander is offline   Reply With Quote
Old   June 23, 2010, 18:13
jed
Jed Brown
jed is on a distinguished road
These suggestions are worthless for sparse systems. I recommend PETSc (http://mcs.anl.gov/petsc), it runs everywhere (Linux, Mac, Windows, exotic Unix, and even iPhone ;-)), scales to very large problems (5*10^11 unknowns, ~300k processors), and perhaps most importantly, is easy to extend with custom (physics-specific) solver components, or by composing existing components (including many third-party libraries) at runtime.
jed is offline   Reply With Quote
Old   June 24, 2010, 02:03
kostas
OK. Thanks. I have installed PETCs library but i havent concerned it still. Yesterday, i try to use SuperLU library but cant invert matrices (only solve systems). In my problem use the same right large matrix more times. Therefore its not efficient to solve a system at each time. Of course, if i use iterative procedure maybe is ok.
Old   June 24, 2010, 06:24
Default You never want the inverse
jed
Jed Brown
Maybe you misunderstand the process of "solving". You don't want the inverse because it's dense and numerically unstable. Instead, you factor the matrix, and then solve with sparse triangular factors. This requires far fewer operations than actually creating the inverse, and the triangular solves are also much faster than multiplying by the inverse (roughly O(n \log n) in 2D or O(n^{4/3}) in 3D vs. O(n^2), time and space). If you use PETSc, you just call KSPSolve() repeatedly (without updating the matrices), this will reuse the factorization that was computed on the first solve. A standard direct solver would be obtained with
-ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu
(or mumps or umfpack, which are likely faster). Note that larger problems, especially in 3D, may be better suited to iterative methods (domain decomposition or multigrid), even if you need to solve many times.
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
C++ solver for Large sparse matrix! sina_mech Main CFD Forum 7 November 20, 2009 13:52
free C code for large sparse matrix linear solver ztdep Main CFD Forum 7 May 24, 2007 14:14
Sparse linear systems in finite volume method Lionel S. Main CFD Forum 6 January 19, 2007 10:04
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 04:22
