reynolds number averaging??
Old   June 26, 2010, 03:46
Default reynolds number averaging??
qrie is on a distinguished road
hi,
im modelling fluid flow over an airfoil using k-epsilon model. my professor says i shouldnt arbitrarily choose any velocity at the inlet, but start from low velocity and "iterate". he wants me to do this:
1. start from low velocity at the inlet,
2. get reynolds number distribution at various y stations
3. ensure that the avg reynolds number is somewhat close to the reynolds number calculated from the inlet velocity.
4. repeat this for progressively higher velocities
my question: why should I do this? wat purpose does it serve? is it because i'm using k-e model and it makes use of Re avgd N-S eqns??
i dont understand his explanation
pls help!!
thanks
qrie is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
