Density functional theory in hydrodynamics
Old   July 6, 2004, 08:18
Default Density functional theory in hydrodynamics
DFT
http://www.densfunc.com/ The density functional approach possesses the following advantages: it takes account of the structure of the interfacial region and of the surface layers the surface tension coefficients are calculated from other parameters of the model the model describes phase transitions and the flow simultaneously including the formation and the decay of phases, the condensation and the evaporation near solid surfaces the model is indifferent to the complexity of the spatial geometry of the considered phases.
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Hydrodynamics of High Density CFB Adnan FLUENT 1 February 13, 2010 21:23
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 03:07
