shock detection in the Riemann problems(specially in the stationary contact problems) |
July 10, 2010, 08:25 |
Rep Power: 19 |
First you should have an analytical solution for your problem if you don't have one (you can compare this with the numerical one):
J.D. Anderson - Modern compressible flow. Second - if your numerical solutions oscillates you probably have an implementation problem: maybe with your boundary conditions or maybe with the order of the numerical scheme you use. For a second order scheme (and high orders) you must use limiters functions in order to remove the oscillations (or you can try with a very fine mesh). Do |
shock detection |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
Slug Flow, interFoam, problems with Contact Angle | PrzemekPL | OpenFOAM Running, Solving & CFD | 13 | February 18, 2014 22:10 |
contact problems for high accuracy Euler algorithm | igor | Main CFD Forum | 0 | May 28, 2003 07:24 |
How to set stationary shock? | Paul | Main CFD Forum | 1 | October 14, 2001 10:31 |
