mesh missing after export in gambit
Old   July 23, 2010, 02:19
Default mesh missing after export in gambit
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi all
i modeled a delta wing (figure 1) in gambit..
i design two volume around it...an interior volume within the exterior..
here are the steps i did for it::
1: import vertices coordinates of the wing..
2: making 5 edges,4faces and 1 volume for the wing..
3:designing the exterior volume
4;subtracting the wing from the exterior volume
5:designing interior volune
6:splitting the bigger volume with interior volume..i mean i devide the exterior volume into two parts.
7:after this , the wing volume is created again, i deleted it again..
now i have two vlolume, one between the wing and the interior volume,,,and the other between the the interior and exterior..
8: for meshing, first i mesh all 4 faces of the wing, then i mesh the space between wing and interior volume with small mesh, and then between interior vol. and exterior with coarse mesh..
9: then i define B.C for all 3 faces of the exterior vol as press. far field..
and define the all volume as fluid..
10;; i export the model as mesh, and dbs..
it saves syccessfully both for dbs and mesh..
but when i import the mesh in fluent , or open the dbs file in gambit again the mesh wil changed,,, i import the mesh file in gambit and i have the same problem ..i mean when i import them again the mesh the interior vol. and its mesh is vanished,,,also three middle edges of the wing geomrtry is vanished too..
what will be the problem..?
and some other questions, for a delta wing in supersonic regime, is this a good modelling procedure,,,?
is it possible to create structured grid around this delta wing? plz tell me the good dimensions of the interior and exterior domains in according to the wing geometry...also what size of mesh will be enough for wing face and two vloumes?
pictures::
http://nfsh.gigfa.com/figure1.jpg
http://nfsh.gigfa.com/1.jpg
http://nfsh.gigfa.com/2.jpg
http://nfsh.gigfa.com/3.jpg
http://nfsh.gigfa.com/4.jpg
morteza08 is offline   Reply With Quote
Problems with gambit mesh lions85 FLUENT 2 August 28, 2009 19:05
export or convert gambit mesh to CGNS zaidun FLUENT 6 April 20, 2006 04:48
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
Export gambit generated mesh moiami FLUENT 0 March 3, 2003 02:53
GAMBIT merge and export mesh sean FLUENT 4 March 8, 2001 07:50
