Eigenvaluesand eigenvector of Euler equations 2 D
Like Tree2Likes
  • 1 Post By DoHander
  • 1 Post By agd
Old   August 12, 2010, 10:14
Default Eigenvaluesand eigenvector of Euler equations 2 D
Miguel Caro
mcaro is on a distinguished road
Hi everybody,
Pleas does anybody have the eigenvalues and eigenvetors of the Euler equations 2D?
Thanks!
mcaro is offline   Reply With Quote
Old   August 12, 2010, 13:04
DoHander is on a distinguished road
check the book of Hirsch - Numerical computation of internal and external flows
Do
kooki_13 likes this.
DoHander is offline   Reply With Quote
Old   August 12, 2010, 13:06
agd
agd is on a distinguished road
Or google "eigenvectors for euler equations" - I got lots of hits that can provide that information.
agd is offline   Reply With Quote
Old   August 12, 2010, 13:49
Default Thanks Do,
Miguel Caro
Thanks again, i checked the book and did not find it.
But searching on the Web, i found an article of Cong Yu, "An efficient High-Resolution Shock-Capturing Scheme for Multidimensional Flows", where are written the eigenvalues and eigenvectors of the Euler equations 2D. Well, i wish to find any book of article where would be more explicit the process of calculate the eigenvector and eigenvalues.
Thanks Do again for your answer
Old   August 13, 2010, 10:39
agd
The eigenvalues and eigenvectors are found using the standard process form linear algebra for the system Ax = lambda*x. In the case of the 2D euler equations you will actually have two matrices, which are the Jacobians that arise from recasting the equations from conservative form dq/dt + dE/dx + dF/dy = 0 into the quasilinear form dq/dt + A*dq/dx + B*dq/dy. Both A and B have their own eignevalues and eigenvectors, which is why you can't diagonalize the entire equation and decouple the system (and why multi-dimensional Riemann solvers are much harder to come up with than one-dimensional solvers). Once you have A and B, then solve the characteristic equation det(A - lambda*I) = 0 for the eigenvalues of A (similar for B), and then solve Ax = lambda*x for the eigenvectors of A (similar for B). It's tedious but straightforward.
ugurtan666 likes this.
Old   August 13, 2010, 21:49
Praveen. C
praveen is on a distinguished road
This may help
http://aero-comlab.stanford.edu/Pape...en_gas_dyn.pdf
praveen is offline   Reply With Quote
Old   August 14, 2010, 09:53
Default I will read it
Miguel Caro
Hi Praveen, i will read it
Thanks
Old   August 24, 2010, 13:00
Default I found the eigenvalues and eigenvector for EUlers 2D
Miguel Caro
The people can find the eigenvalues and the eigenvectors of the Euler equations 2D handly but in this article are yet calculated
An interface tracking method for hyperbolic
systems of conservation laws
Stephen F. Davis ,1992
Thanks everybody who involve with some suggest in this question.
Thanks !
eigenvalues euler 2d
Euler equations & expansion shocks technophobe Main CFD Forum 5 April 28, 2009 15:11
Math. nature of incompressible Euler equations Florian Longueteau Main CFD Forum 14 July 10, 2007 15:55
Quasi-1D Euler Equations Lost in CFD Main CFD Forum 0 March 20, 2007 20:24
Euler equations with heat conduction! salem Main CFD Forum 10 August 2, 2004 03:16
Euler equations? Jan Ramboer Main CFD Forum 2 August 19, 1999 01:58
