Importance of Various Mesh Qualities
Old   August 16, 2010, 13:51
Default Importance of Various Mesh Qualities
Joshua Counsil
Josh is on a distinguished road
Hi all -
I've created a structured C-grid over an airfoil for external aerodynamic purposes. My orthogonality and y+ values are within an acceptable range. The skew is not too high, either. My connectivity values fall within the acceptable range.
However, my edge length ratios (or aspect ratios) around the airfoil boundary layer and in the wake are very high (the maximum values are approximately 1500, whereas a maximum value of 100 is recommended by ANSYS). Similarly, my maximum element volume ratios in the wake and around the airfoil boundary layer are equal to 40, whereas the documentation recommends a maximum value of 5.
In order to decrease these two quantities to an acceptable range, one must refine the grid in the streamwise direction substantially. However, if you do this, the farfield edge length and maximum element volume ratios will be very large (unless you do not allow the normal-to-the-airfoil component of the mesh to expand, which would create a grid of essentially identical elements).
In your experience, how important are these qualities? Is it worth it to obtain acceptable values but have a very costly mesh, or is it reasonable to assume that these high values are inevitable for the simulation at hand? Will these out-of-range qualities substantially alter the lift, drag, pressure, wall shear, and other important measurable quantities?
Thanks for any help!
Josh is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
