Fortran error!
Old   August 10, 2004, 06:48
Default Fortran error!
CFD beginner
Dear CFD people, I can't remove the following fortran error. Any help is appreciated. I use Compaq Visual Fortran Standart edition 6.5.0 and Windows XP. Thanks in advance...
run-time error M6203: MATH - exp: OVERFLOW error
Old   August 10, 2004, 08:56
Default Re: Fortran error!
ag
You're trying to take the exponential of something too big, or you are trying to exponentiate a NaN.
Old   August 10, 2004, 12:28
sijal
this is due to division by zero u can debug by stoping the program at various locatonn espacialy at end of do loop and then use the debug tools of visual fortran 6.5
hope this works but it requires lot a patinece
Old   August 11, 2004, 03:40
CFD beginner
Thanks for all...
I did debugging and solved the error
Old   August 11, 2004, 03:42
SAM
THATS GOOD
Old   August 11, 2004, 06:17
Tim
Compaq visual fortran has a traceback function. If you switch on traceback you are provided with detailed information about the error - including line number file name and subroutine name. This will allow you to locate the problem rapidly.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
user defined function cfduser CFX 0 April 29, 2006 10:58
