September 4, 2010, 20:09 |
Turbulence model for mixing problem???
Nilesh Rane
Hello all,
I am trying to simulate air/fuel mixing in a combustion chamber. I need to specify a turbulence model (RANS) for this. My questions are 1) Which model would be better suited for such kind of simulation?? RNG-k-eps or SST-kW or any other?? 2) About near wall treatment: I suppose k-w does not need a wall function as it can handle near wall flow on its own, am i right?? 3) For RNG k-eps i will have to give some near wall function. Now my dialemma is for coarse mesh (y+ > 30) i have to specify wall function if i use standard k-eps model (which is High Re model in OpenFoam). But what if i use Low Re model like Launder-Sharma?? What about RNG (is it low Re or high Re)?? 4) For mixing problem like this, how much importance the "near wall flow" have??? I am currently doing only cold flow simulations. Thank you.
Imagination is more important than knowledge..
September 7, 2010, 17:44 |
Nilesh Rane
Help...anyone???
September 9, 2010, 15:46 |
Dear friend,
1. For CFD simulation you should use different models to obtain the best solution.we have not general rule for all of the problems. 2. for near wall treatment you can obtain the details with no slip boundary condition rather than wall function but you should use finer grids.y+<5 3.for k-w model your statement is true.it can integrate from sublayer to outer region and needs no matching. 4.I think for your problem the RSM model is better than other models.However you should check this.The best option is LES which is very time consuming. |
September 10, 2010, 03:05 |
cerisier
For me, use a k-w SST with 1<y+<3. Indeed k-w doesn't need a boundary layer, but a very thin mesh (so expensive). If your have experimental result try also other turbulence model (RSM, k-eps realizable enhanced wall). Sometimes it can be better for a compromise time of calcul/ accuracy. If your model is quite turbulent do not hesitate to use my first advise (k-w SST). Concerning RSM it is true that i didn't use it a lot of time... so i can't say it is better than the k-w one. pepi |
September 10, 2010, 05:45 |
siddharth jain
hello ........i think you should go for k-omega SST MODEL........because when u do the analysis, thermal boundary layer will b generated there......that means near wall region is crucial for your analysis........so i think you should go for k-omega SST........
may b this ll work for u frend........ |
September 10, 2010, 11:43 |
Nilesh Rane
Hello all,
Thank you for your valuable opinions. My problem is i dont want to use fine meshes. So i am thinking of using wall functions so i can use coarse mesh at wall. Also my flowfield is mostly vortex dominated, which means free shear flow. If i am correct k-eps is better for such flow, RNGkeps even so. Anyway i am not much concerned about near wall velocity. So i guess i can leave k-w model. Now, can anyone tell me how to specify use of wall function in OF 1.7.0?? Thank you all.
September 13, 2010, 17:56 |
N/A
Before you use wall functions, you need to have a clear idea of their restrictions. Are there any regions of separation or adverse pressure gradients. Older K-epsilon models are known to perform poorly in those regions. If you feel that the wall function will work for your case, I will suggest you to use the k-omega SST model of Menter that is available in OpenFOAM.
September 14, 2010, 04:57 |
#8 | |
Nilesh Rane
Its mixing of air and fuel jets in combustion chamber. So flow separation and adverse P grads. My point is mixing problem like this are not much dependent on the BL on the walls (at least i think so, correct me if i m wrong). The bottomline is i dont want to use y+ ~ 1 mesh, i dont have cluster to solve such big problem. So wall function is a must thing for me. My focus is on jet mixing and if i am not wrong, k-eps model is better for this, and with wall function this should give good enough results. does it seem ok? Thank you.. Nilesh
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
turbulence model equation | Andy Chen | FLOW-3D | 4 | January 1, 2010 21:45 |
Fan heater model: what turbulence source to use? | andy20 | Main CFD Forum | 0 | March 2, 2008 12:46 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 14:16 |
multiphase mixing Problem with MRF model in MixSim | Srinivas | FLUENT | 0 | October 17, 2005 06:35 |
