Droplet detachmant normal to surface by acceleration
Old   April 11, 2022, 17:07
Default Droplet detachmant normal to surface by acceleration
Jane
Jane654 is on a distinguished road
Hey,
I have the folowing problem: I want to detach a Droplet from a Hydrophilic spot by accelerationg the glas with the hydrophilic spot with an explosive( away from the droplets side).
The Rest of the Glas is hydrophobic, so the contact line ist fixed.
How can I calculate or simmulate at wich acceleration how much of the droplet ( for example 50%) will detach?
Sorry if this is a dumb question I am not very firm in Fluid Dynamics
Thanks for your help
Jane654 is offline   Reply With Quote
acceleration, calculation, detachment, droplet, simulation
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Surface Evolver Water Droplet Modeling Actuallyah Main CFD Forum 4 June 23, 2020 16:18
How is the normal unit vector calculated for 2D airfoil surface gradients? Ry10 SU2 5 February 27, 2018 06:28
[swak4Foam] Set surface normal manually in groovyBC Mitchell Baum OpenFOAM Community Contributions 1 March 15, 2016 00:25
Pinning/sticking of liquid droplet to wall surface AkashD OpenFOAM Running, Solving & CFD 0 June 12, 2015 05:11
