Time step when scaling up.
Old   October 19, 2010, 09:32
Default Time step when scaling up.
Craig
LeCatnip is on a distinguished road
Hi there.
Im new to the forum, I have been attempting to scale a simple flow from a small scale to scaling up using a scale factor of 20,000 to a larger scale. I have achieved good results from the small scale models but not for the large.
The large scale works ok when using the same inlet speed as the small scale, but then I am deviding the inlet speed by 20,000 in order to re-create the same reynolds number, and this gives pretty crazy results. My question is should I also multiply the time step by a factor of 20,000 if i reduce the inlet speed by a factor of 20,000? And do i need to change the K and epsilon values for the Reynolds Stress turbulence model which I am using?
Thanks for your help. I hope that was clear enough.
Craig.
LeCatnip is offline   Reply With Quote
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 10:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 17:57
