July 2, 2010, 02:17 |
Mean calculation in LES
Rep Power: 17 |
I am using LES to calculate a completely unsteady flow (not periodic or something predictable in mean). It is of need to calculate the turbulence quantities like kinetic energy and dissipation. The problem is that I don't know how to calculate the means and fluctuations in the unsteady flow? I read somewhere about averaging on a time window about every point in time. Is this possible? If yes, how much should be the window size? I'd appreciate it, if you could mention any other method you might know. Sincerely, Maani |
How initialize calculation using LES approach | tumble | FLUENT | 2 | June 17, 2010 07:16 |
problems with a LES incompressible calculation (pisoFoam) | laurencep | OpenFOAM | 2 | April 22, 2010 04:53 |
LES Spectra in Axisymmetic Calculation | vatant | OpenFOAM Running, Solving & CFD | 0 | October 30, 2006 09:15 |
why in the les calculation, need turbul intensity? | aiya | FLUENT | 0 | June 27, 2006 12:30 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
