KIva source code
Old   October 29, 2004, 02:45
Default KIva source code
Pratap
Hi I have simple question about source code of kiva. Can anyone tell me where all the variables are defined. in kiva. Thanks Pratap
Old   October 29, 2004, 03:38
Default Re: KIva source code
zhvickie
where can you download it?
Old   October 29, 2004, 05:09
Default Re: Kiva source code
Jim K
I have a manual on KIVA. What variables are you interested?
Old   October 29, 2004, 05:57
Pratap
All the variables for example!!!
Old   October 29, 2004, 09:01
Jim_Park
Tony Amsden's standard coding practice was to define variables with comment statements in the main program of each code he wrote.
The documentation usually expanded on those definitions.
Old   October 29, 2004, 09:55
Pratap
I could not find the variable let us say that kiva.f they include the statement "include 'comkiva.i'". Which I have pasted it below. They are not defined in comkiva.i .By definition I mean for using any variable in fortran one should define it as either integer, real or character variable. And one more thing what is this statement *deck comkiva.i. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% *deck comkiva c c comkiva.i status as of December 22, 1998 / 1540 hours: c c nv = maximum number of vertices c nsoot must = 1 if soot is included, should = 0 if no soot calc. c lnsp = maximum no. of species, usually = 12, but = 15 with soot c lnrk = maximum no. of kinetic chemical reactions c lnre = maximum no. of equilibrium chemical reactions c lpres = max. no. of inflow or outflow experimental pressures c nregmx = max. no. of regions created by the grid generator c nper= maximum number of vertices on a periodic boundary c lvap = max. no. of entries in liquid vapor pres. tables in fuelib c nbv = maximum number of boundary vertices c niov = max. no. of inflow or outflow or pressure vertices c nface = max. no. of vertices on piston face c npar = maximum no. of particles present at any one time c lvel = max. no. of entries in the injection velocity table c lnoz = max. no. of fuel injection nozzles c linj = max. no. of times fuel is injected in one engine cycle c nmovemx = maximum number of moving surfaces c nliftmx = maximum number of entries for each valve lift position
parameter (nv=250000,nsoot=0,lnsp=72,lnrk=300,lnre=6,lpres=7 25,
1 nregmx=5,nper=15000,lvap=75,nbv=66000,niov=600,
2 nface=5000,npar=10000)
parameter (lvel=450,lnoz=10,linj=10)
parameter (nmovemx=11,nliftmx=720)
parameter (lsoot=nsoot*(nv-1)+1)
c WARNING: As with all complex CFD codes today, a 60-64 bit word c length is required for KIVA-3. Otherwise, round-off c errors will quickly reduce the results to nonsense. c This implies the use of double precision for all the c real numbers on machines with a 30-36 bit word length. c
common /kiva1/ aaa1(1),x(nv),y(nv),z(nv),u(nv),v(nv),w(nv),
1 ro(nv),vol(nv),p(nv),amu(nv),f(nv),fv(nv),temp(nv) ,sie(nv),
2 bcl(nv),bcf(nv),bcb(nv),alx(nv),aly(nv),alz(nv),af x(nv),
3 afy(nv),afz(nv),abx(nv),aby(nv),abz(nv),tke(nv),pi t(nv),pit1(nv), %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%5 Thanks pratap
Old   October 29, 2004, 12:54
Dino
There are a lot of versions of KIVA. It looks like you may have one of the old versions from Los Alamos. KIVA was developed on Cray computers with 64-bit words. Any variable unless otherwise typed would be real*8 or integer as determined by the Fortran 77 naming convention. The code was written 20 years ago, and at that time they didn't bother to explicitly type everything. Sometimes not anything. There will be very few if any character variables. In that old-style Fortran, the few character strings that may have been used were often done with integer variables.
Another thing to note is that the old versions of that code define all arrays at compile time, there was no dynamic memory management.
Yes, I know, it's crummy programming practice by today's standards, but it was fairly typical of that era.
Hope that helps answer your questions.
Old   October 29, 2004, 13:49
curious
Dino writes :
:> Another thing to note is that the old versions of that code define all arrays at compile time, there was no dynamic memory management.
Is there a way to declare variables at run time in f77 ?
Old   October 29, 2004, 16:36
Jim_Park
Can't remember for sure, but I think that, in the Fortran (77 with Cray extensions)on the Crays of the 70's and 80's, the default floating point word was 64 bits.
For a code the size of Kiva, the comdeck (a block of Fortran statements 'included' near the front of each routine that contained common or dimension statements for variables) was very large. Haven't seen this code for 20 years, so please excuse the fuzzy statements.
This is the section I mentioned in my post above. It relates the input variables to the model equations - which would be in the report you don't have.
deck comkiva c
As the other poster suggested, one of the modern versions of Kiva would likely use F90 or F95 and modern coding practice. But that's my guess.
Take a look at http://www.lanl.gov/orgs/t/t3/codes/kiva.shtml
It appears that some KIVA manuals can be viewed on line.
Old   October 29, 2004, 21:13
Jim_Park
Take a closer look at
http://www.lanl.gov/orgs/t/t3/docs/
I was able to download two KIVA reports from the above URL. There are links to 4 KIVA reports - I tried just the two.
Good luck.
Old   October 30, 2004, 00:53
  #11
Sasidhar
Can anyone tell me what are the different turbulence models used in Kiva. for sure there are RNG model, K-epsilon model and SGS model. Are there any other models too? And which one gives the best results.
Old   October 30, 2004, 06:03
  #12
Pratap
I would like to know the code strcute of old kiva. I think now its kind of mess but if we somebody has good code structure and give me the links : I will appreciate his help. Pratap
Old   October 30, 2004, 08:52
  #13
Jim K
Which "old kiva" exactly? There are many versions.
Old   October 31, 2004, 04:24
  #14
Pratap
Or may be the structure of any kiva code will be helpful to understand the code. Pratap
Old   November 2, 2004, 13:24
  #15
Allan Walsh
In the generic version of KIVA-3 I have, dated Oct. 12, 1993, most of the variables are declared in the common file COMKIVA.I .
We obtained this code from a government lab for a nominal handling fee. It came with separate source code for pre and post processors, which each have variables in their own include file. The code was issued with various manuals.
About 10 years, I fooled with a version to model steady-state combustion, using a PC with a Pentium 90 processor. As the memory was limited (maybe 32 Meg of RAM), I declared variables as single precision.
Isothermal flows were okay, but I didn't have much luck with combusting flow. This could have been more due to my lack of understanding of the code rather than the precision of the variables. And, if you remember, Intel's first Pentium chip couldn't always add correctly - which they neglected to tell people about. Eventually, we drifted off to another commercial code.
If you have an interest in KIVA, you should get an official version. If you are just looking to experiment with a code, and you aren't familar with CFD or Fortran, I would recommend something "SIMPLE"r.
Old   November 2, 2004, 14:22
  #16
Jim_Park
"If you are just looking to experiment with a code, and you aren't familar with CFD or Fortran, I would recommend something "SIMPLE"r."
In my opinion, this is excellent advice!
But, if your professor/instructor/teacher gives you the assignment. GOOD LUCK!
Old   November 8, 2004, 20:39
  #17
Sasidhar
In the k3post file I see that fiels can be generated with extensions *.dpv, *.vel. I am not sure which one to be used for post processing. Can anyone help me. And velout subroutine is defined in such a way that *.vel files generated should contain u, v, w, fv, aux1. But the actual file generated has 6 columns. I don't understant what other column is for.
Old   November 22, 2004, 01:04
  #18
A.S.
Where can I get KIVA source code from. Is it free or low cost software.
Thanks
A.S.
Old   December 2, 2004, 15:59
  #19
adel
hello there i would like to have the comkiva code
Old   July 19, 2010, 05:34
Default shahid
  #20
Haris
riseguess is on a distinguished road
Originally Posted by adel
;31802
Hi
I am a new user with Kiva 3VR2. i have a few very basic questions..
(1)..can i run this code on my PC (windows XP with Fortan 95) or i have ot get Linux installed. if it runs on linux only then what version of Linux??
(2)..i have run it on my pc, there was a message that a file ''Qstart'' is missing. there is no qstart file with in the code (i have browsed briefly)..
Can any one help me out???
Shahid
riseguess is offline   Reply With Quote
User-Defined Scalar (UDS) Source code lig FLUENT 6 October 15, 2014 12:12
SOLA Source code available AminFeizi Main CFD Forum 10 January 14, 2014 14:08
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
heat equation solution source code john Main CFD Forum 1 May 27, 2004 23:41
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
