Poisson Equation in CFD
Old   November 8, 2004, 15:25
Default Poisson Equation in CFD
Maciej Matyka
I am writing a thesis about solution to incompressible NS equations. I have a question regarding Poisson equation, since I need to create a simple example of solution to Poisson equation (I am making comparison of convergence of different Poisson equation solvers as a part of this thesis).
The problem I have is to find a physically meaning of seperated poisson equation:
lapl P(x,y) = -rho(x,y)
I've used an example from electrostatic (p- is a potential and rho is a charge density) but it does not suit the subject of thesis and I am looking for an example from CFD field.
Ok, so question - do you have an idea what can be described (I am looking for simple, simple case) by seperated Poisson equation and will have connection to CFD?
Best Regards, Maciej Matyka <A HREF="http://panoramix.ift.uni.wroc.pl/~maq/eng/">http://panoramix.ift.uni.wroc.pl/~maq/eng/</a>
Old   November 8, 2004, 21:54
Default Re: Poisson Equation in CFD
agg
You could use lapl P(x,y) = -divergence(u dot grad(u))
Old   November 9, 2004, 01:19
Maciej Matyka
Yes, I know that - but I am looking for the most simple poisson equation. That one you've mentioned introduce convective term on right hand, so example from electrostatic is more easy to understand...
Maciek
Old   November 9, 2004, 03:03
Mikael Ersson
Hey,
I don't have a direct answer to your question, but I have a vague memory of this subject being discussed maybe some 6 months ago in this forum. A search might help.
Also a good book I can recommend is Fundamentals of CFD by Roache. He covers the subject quite well.
Good Luck
Old   November 9, 2004, 04:42
Tom
If you mean you want an example of the solution of the Poisson equation which is directly applicable to fluid flow try
grad^2 \phi = -w
with w constant on patches; e.g. w = -1 for x^2 + y^2 <1 and zero otherwise.
In this case psi is the streamfunction and w is the vorticity.
Old   November 9, 2004, 05:04
Maciej Matyka
thank you, that is something what I've been looking for!
Old   November 9, 2004, 22:02
Adrin Gharakhani
If you use patches of vorticity (or even the simpler case would be to use point singularities), you'll be able to use the Biot-Savart law to evaluate the streamfunction and the velocity fields "exactly" (analytically per patch), which you can then use as your benchmark ...
Adrin Gharakhani
Old   November 10, 2004, 01:50
Maciej Matyka
Is the Biot-Savart law applicable in CFD field? As far as I know Biot-Savart law is something in Electricity/Magnetism. So is that only a mathematical law?
Maciej
Old   November 10, 2004, 04:30
Tom
Yes - the Biot-Savart law is applicable. Basically the origin of the concept of vorticity lies in the fact that if you introduce a quantity w=curl(u) then if div(u)=0 the equations linking u and w are those for an electro-magnetic field - div(u)=0 is not referred to as the solenoidal condition for nothing.
See the introduction to the book "vortex dynamics" by P.G. Saffman,
Tom.
Old   November 10, 2004, 11:30
ZubenUbi
With a Dirichlet boundary condition at solid walls and a Neumann boundary condition at inlet and outlet, P could be regard as a "pseudo" distance from the wall (taking into account all walls instead of the nearest. This is of interest for some turbulence model in channel and in vicinity of edges. I used to solve smth like that.
Moreover, the damping function in turbulence model, which usually depends on distance from the wall, modelize, in fact, the non-local effect of pressure fluctuation....
Regards,
ZubenUbi
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
orlandi code for poisson equation with FFT ( paid tutorial) HaKu Main CFD Forum 0 June 29, 2009 15:40
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
Iterative equation solvers in CFD Vitaly Bulgakov Main CFD Forum 32 March 1, 1999 11:11
