Thermochemical data.
Old   November 17, 2004, 15:48
Default Thermochemical data.
H. T. Weesa
Hi all,
I was wondering if anyone knew a good place to try and understand the thermochemical data of Burcat etc. I am having difficulty understanding, for example, how the polynomial data for say, enthalpy, can be used to give me burnt temperature if I know that I have a CH4 and air lean premixed system at room temperature (298.15K). It seems to use the room temperature to calculate the enthalpy and then uses that enthalpy to give a burnt temperature, all using the polynomial data. The system is constant enthalpy since it is adiabatic and constant pressure and volume. How does a constant Enthalpy system affect the equation"
Ho_subscriptT = Delta_f_Ho_298 + (Integral from 298 to T) of Cp_o dT.
where Delta_f_Ho_298 is the enthalpy of formation and CP is the specific heat at constant pressure.
If the enthalpy doesn't change in the system between burnt and unburnt states, then what happens to the terms in this equation for example in a CH4-air or Propane-air reaction.
Any books or ideas are appreciated.
Old   November 24, 2004, 04:48
Default Re: Thermochemical data.
versi
search a JCP paper "High accuracy numerical methods for thermally perfect gas flows with Chemistry" by Fedkiw and Osher. It may be help.
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
