fluid mechanics HELP!!
Old   January 15, 2011, 04:42
Default fluid mechanics HELP!!
Shishir
Adren022 is on a distinguished road
I have not been able to find any software thats helping me in simulating or Obtaining results for pressure drop through a nozzle of decreasing diameter.
having tried the fluid option in ansys v10 dinn't understand how to use it,i have not undergone any training for the other software available for fluid simulations
is there a software that will help,ANSYS 12 and 13 are too costly to buy.
i don't know how to use star CD or open foam,for a noob which would be the best software to use for the above application i have mentioned.
i have to prove that my theoretical results are right with the help of a simulation
thank you
Adren022 is offline   Reply With Quote
Old   January 18, 2011, 07:06
RossFS is on a distinguished road
Surely there are experimental results in tables or charts which would save you the effort of trying to simulate the flow. Find a decent text book.
RossFS is offline   Reply With Quote
Old   January 18, 2011, 10:33
Shishir
i was hoping i could simulate it...But as you say i will look at other alternatives
do you have any suggestions of text books i could use ?
i use a book authored by DR.R.K.Bansal he is a local author,its a well written book but contains only basics
Old   January 18, 2011, 16:01
Having recently only started to conduct CFD simulations myself in ANSYS, I'd say that a little knowledge in this area is very dangerous as with out some good knowledge about the numerical methods used by the software and knowledge about the correct fluid settings to put in, you can very easily generate garbage for output but you are unlikely to know this.
CFD simulations themselves have to be validated with experimental results generally (just read up on the amount of calibration work the F1 guys do with their wind tunnels and CFD software), so I'd lean towards the experimental data.
search via: http://books.google.com/
you are likely to get a graph up of what you want exactly without having to head for a library.
Old   January 18, 2011, 20:56
DoHander is on a distinguished road
Check this book:
http://www.amazon.com/Computational-.../dp/0070016852
especially chapter 7.
If you need help implementing the algorithm send me a message and we'll see how if I can help you.
Do
DoHander is offline   Reply With Quote
Old   January 19, 2011, 00:11
Shishir
Originally Posted by DoHander View Post
Check this book:
Do
thank you ...i will see if its available in my country or order it through flipkart
the above posts make more sense..i have zero knowledge in this field and don't really know which software to use,also we were taught only ANSYS 10 so i have no idea about the newer versions
are there any software that you'd recommend for noobs in this field ?
Old   January 19, 2011, 00:13
Shishir
Does simulation have to take place only using CFD techniques ?
can't i just use the fluid option in ANSYS 10 and get results for this ?
PRACTICAL fluid mechanics & heat transfer for engineering applications - textbooks? JBL Main CFD Forum 0 May 17, 2010 11:32
The concept of DOF in fluid mechanics and CFD bearcat Main CFD Forum 8 May 27, 2007 18:02
Dictionary of fluid mechanics Lam Main CFD Forum 1 April 26, 2007 10:18
Study fluid mechanics in Russia neo Main CFD Forum 4 September 17, 2006 06:09
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
