using ghost fluid method in shock tube problem
Old   February 22, 2009, 07:18
Default using ghost fluid method in shock tube problem
Amir
I want to solve shock tube problem by level set method. Also I want to use ghost fluid method. is it necessary to use WENO5 For solving Euler equation, in one side of discontinuity ? Could I Use Roe's method (for example in Clawpack Software) for this purpose? In solving compressible problem by ghost fluid method, does Euler solver have any certain property?
Old   February 22, 2009, 07:41
Default Re: using ghost fluid method in shock tube problem
jinwon park
I also concerned about this problem in my ph.d program. I used the ghost fluid method to distinguish two fluids separated by a material discontinuity. The GFM is a way to treat discontinuity across the material interface. To identify the interface during computation, an interface method such as level set method requires to be included in it. Any compressible flux function such as ROE, WENO or somethign else is the second problem. It may be used to discretize problem domain in space. Do not confuse between the discretization method, the two-fluid method and the interface method.
Old   February 22, 2009, 12:02
Amir
thank you for your kind response. as you mentioned, I know there is too many differences between space discretization and level set method. I want to know, Could I use Roe solver for discretizing my problem domain? ( But not in my interface) for evolving my interface, I use the level set method. and could you please send me your Phd Dissertation? thank you. I am looking forward for your kind response.
my email is
a_mansouri@modares.ac.ir
amir2920@gmail.com
Old   July 8, 2009, 13:26
Nishant Kumar
Nishu is on a distinguished road
Can someone send me the 1D code for shock tube problem at babuu.nishu@gmail.com? I need it for my research.
Thanks alot
Nishant
Nishu is offline   Reply With Quote
Old   February 24, 2011, 10:09
Smile Question about paper
Sergey Belov
Sergey Belov is on a distinguished road
Send a message via Skype™ to Sergey Belov
Originally Posted by jinwon park
;59032
Dear jinwon ,
My name is Sergey Belov. Both I and my scientific supervisor develop the finite difference schemes for partial differential equations (PDE) and test them on The Shock Tube Problem to descrabe the flowing of gas in pipes. I have a question: do you have any links on the "fresh" papers or books with numerical results of solvig PDE where The Shock Tube Problem is considered as a test problem?
Sergey Belov is offline   Reply With Quote
Shock tube simulation harish FLUENT 5 January 25, 2014 02:20
Level set and Ghost Fluid Method alvin11 OpenFOAM 1 December 6, 2011 04:10
plotting not working (shock tube problem) cfdguy2008 FLUENT 0 July 24, 2008 12:50
Shock tube problem AB Siemens 1 November 9, 2004 00:25
shock tube: problem initiation Gareth Siemens 3 April 15, 2003 03:23
