Low reynolds number flow
Old   February 5, 2011, 12:06
Post Low reynolds number flow
pranav r
pranavr is on a distinguished road
What are the equations aplicable in the case of a low reynolds number flow as in the case of a flow past an airplane made of paper
pranavr is offline   Reply With Quote
Old   February 7, 2011, 15:50
truffaldino's Avatar
truffaldino is on a distinguished road
You should solve incompressible Navier-Stokes
truffaldino is offline   Reply With Quote
Old   February 8, 2011, 04:29
Muhammad Aqib Chishty
aqib is on a distinguished road
depends upon the problem and your area of interest....
Reynolds Averaged Navier Stroke's Equation(RANS).... is to be the best to catered flow separation
aqib is offline   Reply With Quote
Old   February 16, 2011, 05:35
jvr
jvr is on a distinguished road
hi,
i want to calculate the Reynolds number of exhaust gas with a given temperature(°c) and massflow(g/s).
What is the fastest way?
thanks in advance
jvr is offline   Reply With Quote
Old   February 17, 2011, 00:51
i think as per my knowledge, your flow is compressible and their should be some laminar separation....
the best model to catered that is Menter Transition model of 4 four equations....
Old   February 21, 2011, 09:53
Shenren Xu
Shenren_CN is on a distinguished road
I'm afraid low-Re # does not imply low mach number.
You can get shock wave for inviscid fluid, where the Re # is zero.
Shenren_CN is offline   Reply With Quote
Old   February 22, 2011, 10:42
This thread is about aerodynamics of a small (paper) airplane.
Have you seen shok waves past paper airplane?
BTW, for inviscid fluid RE=infinity
Old   February 22, 2011, 11:04
Shenren Xu
Hi truffaldino,
my apology... I didn't read it carefully.
And you are right, Re # is infinity.
hope my advisor is not reading this...
Old   February 22, 2011, 12:36
Vasiliy
Vasiliy is on a distinguished road
Hi All,
My opinion that transition model is not necessary in this case.
As I understand air flows around paper plane. So velocity is small and we can use incompressible Navier Stokes equation.
About turbulence models. I think SA model is good choise in this case. Flow is not very difficult.
I am not sure about transition and separation on paper plane.
Vasiliy is offline   Reply With Quote
Old   February 22, 2011, 15:05
I had quite extensive experience with model gliders, they fly at about the same order of RE as paper planes and there is almost always separation and transition there.
Old   February 23, 2011, 01:00
Vasiliy
Hi truffaldino,
It looks like nice case. It would be interesting to have such model and experiment results. Could you provide it.
Thanks
Old   February 23, 2011, 02:33
Hi Vasiliy,
Information about low reynolds number airfoil design and its peculiarities (due to separation/transition bubbles) is quite extensive and easily acessible over the web. As an example you could take a look at Martin Heppelere website, and in particular
http://www.mh-aerotools.de/airfoils/
Data on very slow airfoils for Discus Launch Gliders (down to RE=40K) can be found here
http://www.charlesriverrc.org/articl...t-airfoils.htm
People from RC glider commmunity mainly use Mark Drela's xfoil and also XFLR5 software. These are nice programs that are free and increadibly easy to use: Xfoil analyses airfoils, while XFLR5 analyses an airplane as a whole.
These programs are based on viscous-inviscid interaction method with boundary layer integral methods. They use e^n transition model and some turbulence model.
One can also have a rough idea about presence of separation at low Re for 2D airfoils even without using the above software: one can use Thwaites integral BL method. It is very simple and takes a couple of hours to write a program in mathlab or maple.
About experimental data: there has been an extencive testing by UIUC Applied Aerodynamics group, and measured polars were available free of charge on the web. Now they are selling them as reference books: see e.g.
http://www.ae.illinois.edu/m-selig/uiuc_lsat.html
but some of them are still scattered over the internet free of charge
Truffaldino
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Reynolds number for flow over half cylinder? Haroon10 Main CFD Forum 0 April 23, 2009 10:09
Coupling of RNG k-e and Low Reynolds number k-e Amaranath FLUENT 0 January 16, 2008 08:08
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
