Converting .dwg files to .stl
Old   February 12, 2011, 08:02
Default Converting .dwg files to .stl
Sen
Sen
Sen is on a distinguished road
I want to convert .dwg file into .stl format ..I couldn"t do the conversion with autocad ..so is there any converter available for converting files to .stl format or to .igs ?
with regards,
Sen
Sen is offline   Reply With Quote
Old   February 12, 2011, 10:09
Nuno Gomes
Dinocrack is on a distinguished road
Its a 2D file or 3D?
I am not sure, but 2d dont fit in stl.
But, you can import your dwg to a 2d sketch in solidworks, transform into a solid , and save it as stl or igs...for example...
Regards
Nuno
Dinocrack is offline   Reply With Quote
Old   February 12, 2011, 11:59
Default Thanks dude
Sen
Sen
yeah its a 2D file ..
Old   February 14, 2011, 05:37
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
rhinocerous (30 day free trial) should be able to do it
sail is offline   Reply With Quote
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 15:08
