Numerical Weather Modelling : Time and space resolution issues |
February 15, 2011, 21:32 |
Christophe Sibuet Watters
Although I am experienced with CFD and numerical modelling of fluid flow, I have some difficulties to solve the following question : My problem is the following : I wonder down to which time resolution, the solution provided by a numerical weather prediction (NWP) model can be considerred to be realistic and physical, providing the typical hypotheses involved within operational NWP models. For example, let say I can measure the wind at a given place. On a minute to minute basis, I can observe the wind to vary. These variations come from turbulence (mechanical and thermal) and from the large-scale weather motion. Of course, in a numerical solution, variations of the wind component also exist, but what is the limit down wich these variations are purely numerical, and have nothing to see with reality ? What would be the limit in time below which timestepped solutions should not be kept, and only time averages should be considerred instead ? The typical hypotheses used in NWP models are : - Treatment of small scale turbulence by turbulence closure of zero-order (mixing-length type treatments) - Treatment of larger scale turbulence id. LES models ; NWP models respect CFL conditions. For example, a 15 km resolution model will use a Dt of 45s. I imagine the response is a function of the spatial and time resolution of the NWP model, and probably of local wind velocity... but I can not figure it out on my own, since most of the problems I have studied in the past are steady over time !!! any advice or thought on the subject is very welcome ! Chris |
numerical weather |
Variable BC in time and space for transient run | Porry | CFX | 2 | February 21, 2012 09:38 |
Richardson Extrapolation to check time and space convergence | Hooman | Main CFD Forum | 0 | December 29, 2010 08:19 |
Time and Space Derivatives. | beezee99 | FLUENT | 0 | August 19, 2010 01:34 |
Space and time discretization of Euler equation | Hooman | Main CFD Forum | 2 | June 6, 2010 08:30 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
