COG(Coke Oven Gas) Combustion Problem in "W" Type Radiant Tube
Old   May 20, 2009, 23:55
Default COG(Coke Oven Gas) Combustion Problem in "W" Type Radiant Tube (3D)
Kang Jung Shin
sdlafkj is on a distinguished road
Hi, Everyone
I'm trying to solve heat problem of "W" type radiant tube
<Grid Design>
-------------------- <= Fuel & Air Supplying Line
-------------------- => Exhaust Gas Out
When setting up CFD-ACE Model,
#1. Chemical Reaction : CH4+2O2 -> CO2 + 2H2O "For Whole area of tube"
-> Is It Right?
#2. And When I do set up CFD-ACE Model like #1,
In the 1st straight line(the most upper line), There is no CH4 mass fraction (=0) at all!!
Why this happens? Did I do something wrong?
sdlafkj is offline   Reply With Quote
Old   May 21, 2009, 02:22
Kang Jung Shin
Hi, All. I got a clue~ Sorry to produce garbage..
Old   February 19, 2011, 01:54
Default Coke Oven Gas combustion in W radiant tube
eegala is on a distinguished road
I am trying to model a W radiant tube for burning COG( containing mostly H2 and CH4). can u give me a basic idea for modeling in CFD. The flow of air and gas are co-axial.
1) can I model it in 2D, or 3D is necessary?
2) which reaction chemistry can be used. I want to use CH4 and H2 combustion chemistry.
I want to model it using ANSYS-FLUENT
eegala is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Combustion Problem Arnab Siemens 2 April 29, 2009 08:13
Sod shock tube problem with real gas effects ganesh Main CFD Forum 0 October 17, 2006 01:22
