stability
Old   January 18, 2005, 05:53
Default stability
Baskar
sir i have made a program using finte diffrence implicit method for one dimesional problem. as time step increases the values are also changing. how to check stability for the implicit method so that for all time steps value remain same. thanking you s.baskar
Old   January 19, 2005, 10:55
Default Re: stability
Alexander Starostin
Hi, Usually one must talk about method stability exactly only for very simple equations with very simple BC. There are several theoretical ways to reveal unstability. I can remind one of them but probably you just need to check the stability of your method numerically. Change the grid and time steps and see what happens. Your results for different grids should coincide.
I read you again and didn't quite understand the following: ...stability for the implicit method so that for all time steps value remain same... What value do you mean? Didn't you mix up stability and stabilization? Your problem is still very vague for me.
Stability Derivatives embolado FLUENT 0 December 27, 2010 01:12
stability and number of processors ?? sersunzo OpenFOAM Running, Solving & CFD 0 June 9, 2009 11:45
Stability Condition for Immersed Boundary Method Dave Rudolf Main CFD Forum 0 February 5, 2007 23:36
Hydrodynamic Stability vs CFD Ben Main CFD Forum 2 October 18, 2004 02:39
Solving linear stability eq. K S Chang Main CFD Forum 3 January 19, 2004 16:01
