January 12, 2005, 04:14 |
LES for channel flow
I'm writing my own CFD code. So far it is only 2D. If I apply the LES Smagorinsky model for trubulent channel flow, should I expect good results in 2D? Will the average velocity profile look anything line the DNS?
Thanks! |
January 12, 2005, 05:14 |
Re: LES for channel flow
I think not. You can only perform a good LES simulation in 3D because the turbulent structures (vortices) break down in the third dimension. You can try, but I think that you'll obtain very poor results from a 2D simulation...
January 12, 2005, 17:32 |
You will most certainly not get the same results. 2D turbulence is dominated by reverse energy cascades (small scale to large scale).
January 17, 2005, 16:10 |
What you could do is perform your 2D simulation in 3D with periodic BC in the third direction. That way you might be able to compare your results with those in literature.
January 20, 2005, 06:59 |
for the beginning Turbulence is three dimensional. Anyway, in practice are also 2D turbulence simulations. What you cannot do is to compare 2D LES data with 3D DNS data... regards, tele |
integral length scale and cross-correlation (with openfoam data, LES pipe flow) | jet | Main CFD Forum | 1 | November 7, 2016 04:23 |
LES transitional pipe entrance flow | hasanduz | Main CFD Forum | 2 | October 11, 2013 17:59 |
No Fluctuatios in LES results for pipe flow!!! | Roohi | CFX | 5 | September 7, 2011 18:50 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
