Arrays in Fortran & C
Old   December 11, 2004, 08:44
Default Arrays in Fortran & C
SwF
I got accustomed that in Fortran A(i) is i-th element of the array A, but in C/C++ A[i] is (i+1)-th element of the array. Is it possible to do (to work) with indexes of arrays in C/C++ as in Fortran?
Old   December 11, 2004, 19:24
Default Re: Arrays in Fortran & C
zxaar
you probaly want to say that in C/C++ arrays A[i] is i - 1 th element , ..... since arrays in C/C++ start at element 0, that is array with size 5 is 0 1 2 3 4 (from element index) ..... and in the end .... in all the computer languages ... A[i] means ith element .. only in C if you try to access A[array-size] it will give you an exception ....
Old   December 11, 2004, 19:52
andy
Yes. You can overload ( and ) in C++ but why bother? But more importantly in C/C++ arrays are not arrays in the Fortran sense but only pointers. This defeats the optimiser (aliasing) and leads to lower performance.
Old   December 12, 2004, 02:04
SwF
To zxaar: let i=0, on your logic A[0] is 0-1=-1-th element of the array (minus one element, i.e. nonsense). In fact: A[0] is 0+1=1-th element (the first element of the array). Is not it?
Old   December 12, 2004, 02:37
zxaar
but by your logic ... let i = 0 , then if u ask for A[0] computer shall return you A[0+1] or A[1] ...so please read first what you have written ... then we will think on other logic ...
Old   December 12, 2004, 03:21
SwF
I use logic accepted in Fortran and in usual life: a[0] is the first element, a[1] is the second, etc.
Suppose I have a piece of code in Fortran:
real*8 a(1:100),b(2:99)
do i=2,99
b(i)= a(i-1) - 2.0*a(i) + a(i+1)
end do
Please write this piece in C/C++.
Old   December 13, 2004, 11:06
andy
I think I misunderstood your question first time. You cannot do it in C but you can in C++ if you want to make the effort. Here is an example:
http://math.nist.gov/tnt/
of some relatively straightforward to understand C++ (unlike most). It will, of course, take ages to compile, require you to use the same version of the compiler for all code and be slower than Fortran but it can be done.
Old   December 13, 2004, 12:45
Praveen
If you want an array of size N just allocate for N+1. Then use the indices from i=1 to i=N as in fortran.
real a[N+1];
for(i=1; i<=N; i++) use a[i] for some computation
You will be wasting a[0] but no big deal.
Old   December 13, 2004, 14:25
D.M. Lipinski
SwF,
If you declare A as a ponter in C/C++ (i.e. double *A) , then allocate the required N elements with calloc/malloc. Now, you can pass A-1 instead of A into your C/C++ function. By doing this you pass just a fictitious address (one element less than the address of A) and, within the function, you can access the first element of A as A[1], i.e. fortran-like.
Hope it solves your problems
regards
DML
Old   December 14, 2004, 10:01
Amadou Sowe
I think this might be useful in attempting to do what Lipinski suggested:
#include <stdio.h> #include <math.h> #include <stdlib.h> #define N 101
int main() {
double *a, *b, pi;
int i;
/* Allocate memory for vector a so index manipulation instead can be done */ if((a=(double *) calloc(N, sizeof(double)))==(double *) NULL){
perror("calloc:a:"); /* Gives error message if memory not allocated */
exit(1); }
/* Allocate memory for vector b so index manipulation instead can be done */ if((b=(double *) calloc(N, sizeof(double)))==(double *) NULL){
perror("calloc:b:");/* Gives error message if memory not allocated */
exit(1); }
pi=4.0*atan(1.0); for(i=1;i<N;i++){ a[i]=pi*i; printf("a[%d]:%f\n",i,a[i]);
for(i=2;i<N-1;i++){ b[i]= a[i-1] - 2.0 * a[i] + a[i+1]; printf("b[%d]:%f\n",i,b[i]); }
free(a); /* Free up allocated memory for vector a */ free(b);/* Free up allocated memory for vector b */
return 0; }
Old   December 14, 2004, 10:55
  #11
Amadou Sowe
SwF,
I tried pasting the example in but it did not come out right. The print statements are some how missing. I can send it to you if you give me an e-mail to send it to.
Old   January 14, 2005, 07:43
  #12
Alexander Starostin
If you've got inevitably accustomed. Always create in C the arrays with plus one extra element.
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 15:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 09:34
