LES for channel flow
Old   January 12, 2005, 04:14
Default LES for channel flow
Smilodon
I'm writing my own CFD code. So far it is only 2D. If I apply the LES Smagorinsky model for trubulent channel flow, should I expect good results in 2D? Will the average velocity profile look anything line the DNS?
Thanks!
Old   January 12, 2005, 05:14
Default Re: LES for channel flow
Dieter
I think not. You can only perform a good LES simulation in 3D because the turbulent structures (vortices) break down in the third dimension. You can try, but I think that you'll obtain very poor results from a 2D simulation...
Old   January 12, 2005, 17:32
noName
You will most certainly not get the same results. 2D turbulence is dominated by reverse energy cascades (small scale to large scale).
Old   January 17, 2005, 16:10
agg
What you could do is perform your 2D simulation in 3D with periodic BC in the third direction. That way you might be able to compare your results with those in literature.
Old   January 20, 2005, 06:59
tele
for the beginning Turbulence is three dimensional. Anyway, in practice are also 2D turbulence simulations. What you cannot do is to compare 2D LES data with 3D DNS data...
regards, tele
integral length scale and cross-correlation (with openfoam data, LES pipe flow) jet Main CFD Forum 1 November 7, 2016 04:23
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
No Fluctuatios in LES results for pipe flow!!! Roohi CFX 5 September 7, 2011 18:50
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
