DNS -low Reynolds number Airfoils
Old   January 12, 2005, 21:44
Default DNS -low Reynolds number Airfoils
Pat
I've just started a DNS project on airfoils at low Reynolds number (Eppler 61 at Re_c = 42,000). Therefore, let me know if you have any knowledge in this particular field or if you have any comments, advices or papers about the topic.
Thanks,
Pat
Old   January 13, 2005, 10:57
Default Re: DNS -low Reynolds number Airfoils
Jarmo Monttinen
TJ Mueller from Notre Dame has some data on his 1999 MAV paper (presented at VKI), computations are done by Greg Brooks using Cobalt.
I was not able to match his results though, despite using the same mesh. It has been couple of years since I worked on this, so I don't remember the details.
-- Jarmo
Old   January 21, 2005, 14:17
Frederic Felten
Hi there,
Check the following website: http://www.aae.uiuc.edu/m-selig/
UIUC Applied Aerodynamics Group Department of Aerospace Engineering University of Illinois at Urbana-Champaign, Urbana, Illinois 61801 (M. Selig)
Sincerely,
Frederic Felten
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 14:08
Low reynolds number flow pranavr Main CFD Forum 11 February 23, 2011 02:33
Fluent 12.0, Low Reynolds Number Flows anandvksin2003 FLUENT 1 January 26, 2010 05:16
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 08:34
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
