January 22, 2005, 04:11 |
How to run parallel in ICEM_CFD?
Hi , I can run solver parallel in CFX-5.7.1, and I'm wondering if it's possible to run parallel while meshing in ICEM_CFD5.1 ? Thanks!
January 24, 2005, 04:10 |
Re: How to run parallel in ICEM_CFD?
If you have a dual processor machine you can run the mesher locally parallel. Go to Settings->General and set number of processors to 2. You can't run the mesher as a distributed parallel process.
January 24, 2005, 08:53 |
Thanks for your response!
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
Unable to run OF in parallel on a multiple-node cluster | quartzian | OpenFOAM | 3 | November 24, 2009 13:37 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 08:33 |
Parallel run diverges, serial does not | SammyB | OpenFOAM Running, Solving & CFD | 1 | May 10, 2009 03:28 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
