August 7, 2010, 10:13 |
Supersonic combustion
Roshan S Lal
Rep Power: 15 |
Hi friends
I'm trying to model a supersonic reacting flow with crosswise injection of hydrogen gas at mach 1 into mach 2.5 main air stream. I'm using finite rate combustion model with the fluent 6.3 solver I want to find the combustion efficieny. And in the papers its given as ηc = 1 – [ ∫αρu dA / ∑m fuel in ] ; α = mass fraction of fuel How to evaluate this formula with fluent reports. Should I find the term ∫αρu dA by surface integral and flow rate with α as the variable. Is there any other means to get efficiency of combustion Roshan |
August 28, 2010, 21:13 |
#2 | |
aditya
Rep Power: 15 |
August 29, 2010, 00:41 |
Roshan S Lal
Rep Power: 15 |
I ve mentioned it - FINITE RATE MODEL is being used for the supersonic combustion
August 29, 2010, 19:59 |
aditya
Rep Power: 15 |
August 29, 2010, 20:10 |
aditya
Rep Power: 15 |
can u give me any supersonic combustion releted paper or case data file of combustion i highly appreciated you. thanks.
hello2apsingh@gmail.com actually i have tried many time but till now i am not success in supersonic combustion plz help me thanks |
August 31, 2010, 11:45 |
Roshan S Lal
Rep Power: 15 |
Yar I'm also trying to get the solution but not succeeded yet. But i think as far as supersonic simulation is concerned, U need to use density based solver. The models u mentioned is applicable for pressure based one, ie not supersonic
September 2, 2010, 01:45 |
aditya
Rep Power: 15 |
if we are using density based and taking air as ideal gas and if we using finite rate /eaddy dissipation model it shows only mixing and not burning of the fuel. and after some changes it show turbulence viscosity limited or absolute pressure critical.
have u done on any supersonic combustion kilnly help me thanks |
September 3, 2010, 05:55 |
Roshan S Lal
Rep Power: 15 |
hi how do u know that it gives mixing only? i think when reaction is enabled there is the possibility of starting combustion, provided it has enough temperature to start reactions. i want to know how should i ascertain that burning had occured??
i'm doing work on cavity. Using this way i got enough mass fration of pdt of combustion, H2O. but it is not happening in the regions as seen in the literature. I have also the same doubt wheather combustion modelling is not the proper one. Yar if this is not the way then what can be ?? Help plz |
March 16, 2011, 05:52 |
#9 |
aditya
Rep Power: 15 |
hello If any one need help regarding any combustion model supersonic or hypersonic or subsonic,2d les modeling or 3d. write to me at hello2apsingh@gmail.com
Thanks |
Supersonic Combustion | Andrew | FLUENT | 1 | March 16, 2011 06:00 |
help in modelling supersonic combustion in Fluent | omar.2002bh | Main CFD Forum | 1 | March 16, 2011 05:58 |
2d supersonic combustion with H2 gas | Roshanlal | FLUENT | 0 | August 3, 2010 10:25 |
A supersonic combustion in a Laval nozzle | argeus | FLUENT | 0 | March 29, 2010 13:52 |
which combustion model can be in supersonic field | cfdfans | FLUENT | 0 | March 9, 2001 22:13 |
