turbulence
Old   February 9, 2005, 05:34
Default turbulence
abdou
I want to use a best turbulence model for impinging jet. can anyone tell me which one is preferred in this issue. thank for any help.
Old   February 9, 2005, 05:53
Default Re: turbulence
Shubidu
Use the V2F model cos it is capable of predicting the secondary peak in heat transfer at r/d=2.
Old   February 9, 2005, 06:00
abdou
thank you for your response. but what do you mean by secondary peaks. and can you give me a recent title on the field. abdou
Old   February 9, 2005, 06:08
A.S.
Have a look at Professor Durbin's at Stanford University. He has worked on impinging jet analysis using v2f model.
http://me.stanford.edu/faculty/facultydir/durbin.html
A.S.
Old   February 10, 2005, 04:18
RAJURAMAIAH
hi,
Even I am also doing some reserach in this area , so Prof Durbin has done lot of work on this jet impingment and V2f is tooo good for predicting all the parameters.
RAJURAMAIAH
Old   February 12, 2005, 06:22
dd
I think that model SST can be more interesting dd nvs
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
